Window problem
Old Jul 3, 2014 | 06:22 AM
Lonerangerlax's Avatar
Window problem
It all started with the rear passanger side window opening on iy's own and not going back up, the passanger, and rear driver side windows not working. The rear passanger window would close upon start up of car, sometimes. I checked for loose conections, and fuses- nothing! So I brought it to a mechanic who diagnosed the window lock swith was defective. He wanted a great deal of money to fix the problem, so I held off. I purchased a switch and replaced it myself and nothing happened.
To recap, the driverside window works. The rear passenger side window is down, passenger and driver side rear window is up, and all nonresponsive.
Old Jul 4, 2014 | 10:12 AM
Gman56's Avatar
I had a similar problem with my 05X rear would go down not up .replaced master controls on driver side problem gone!
Old Jul 8, 2014 | 03:38 AM
Omar96a's Avatar
try putting the window down a little more than half way then pull the window switch all the way up when it closes keep holding the window switch up for 3 seconds then let go! that restarts your window on whatever side you did it for.
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
