2003 g35 overheating!! Need help
Old Aug 4, 2014 | 08:37 PM
sok1989's Avatar
hi i just recently had this overheating problem out of no where
i just recently change my oil cooler gasket and change my oil and oil filter and add new coolant i thought it be fine but when i took it for a test drive around a few block and notice the temp gages jump almost to the H..any help can be useful and appreciated thanks
Old Aug 4, 2014 | 09:07 PM
danoman32's Avatar
Air in the system, bleed bleed bleed. When you think you've done it enough, do it again.
Old Aug 4, 2014 | 09:11 PM
sok1989's Avatar
is there a proper way of bleeding it any videos pics would help will i be needing new coolant thanks
Old Aug 4, 2014 | 09:27 PM
ScraggleRock's Avatar
^yup. Use that bleeder valve, bro.
Old Aug 4, 2014 | 09:34 PM
There's a plastic cap near the passenger side of the firewall that has a big Phillips driver notch. Take that cap off, take the radiator cap off, turn on the car and fill the radiator until you see coolant running thru that bleed line. Do that about 17 times and you may have all the air out. If not, do it again. Haha our cars are a pain when it comes to bleeding the coolant system.
Have someone sit in the driver seat and keep an eye on the temp.
sok1989's Avatar
will i need a spill free funnel? or new coolant to proper bleed it? thanks
Old Aug 4, 2014 | 09:36 PM
Not new coolant if you just put it in. Just more. No special funnel is needed, no. Those funnels just make it a bit easier.
Old Aug 4, 2014 | 10:39 PM
sok1989's Avatar
Have so eone sit in the driver seat and keep an eye on the temp.
okay im trying that now..
do i fill the reservoir tank also?
do i also keep filling it up when the reservoir tank goes down
thanks
Old Aug 4, 2014 | 10:44 PM
Yeah, fill it to the max line and keep filling it as it sucks it up.
Old Aug 5, 2014 | 01:08 AM
Eric@TCGMiami's Avatar
x2
As he said, the Spill Free Funnel kit makes the process go by so much quicker.
If you have a sedan as I fear you do (and hope lol) there's a way to make it a quicker process. Just takes a bit of skill and knowledge. Typically to air out the car the proper way it'll literally take 1/4 of a tank of gas and even then in the morning you may have to recheck it before turning back on.
Old Aug 8, 2014 | 12:57 PM
ModBargains.com's Avatar
Ouch. Hope we can help. Welcome to the site!
TWASkyliner
Feb 8, 2020 08:00 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Rehman2009
Jul 27, 2015 03:23 AM
Chattzx
Jul 17, 2015 11:23 AM
