Enjoying my first G35 (06 Coupe)
Old Jan 31, 2015 | 10:29 PM
Mr. Brooks's Avatar
Any results from the spacer.
Old Jan 31, 2015 | 10:41 PM
Lolik0's Avatar
nice and clean. good job on the upgrades ive had mine for almost 2 years now and havent gotten to the upgrades ive wanted only the z tube and K&N. saving to buy a house has car on the backfoot so congrats getting ur work done man.
my to do list is: MREV, spacer, HFC and exhaust. uprev tune then brakes. probably a paint job urs is much cleaner then mine is good find. if u dont mind me asking price and mileage?
Old Feb 1, 2015 | 01:07 AM
Bucky727's Avatar
The spacer made it more responsive all the way through the rpm range and was well worth what I spent for it. Right now it has 90k miles, it had 87k miles when I bought it last fall for 11,500, 1 owner car. Next up will be a performance tune along with S-tech springs & H&R wheel spacers.
Old Feb 1, 2015 | 07:44 PM
Hogbone's Avatar
I went with 25mm wheel spacers and it changes the whole look of the car! I recommend you going the same size
Old Feb 2, 2015 | 12:07 AM
Bucky727's Avatar
Rubbing?
I would like to get the thickest possible spacers that would allow my sidewalls to run as close to edge as possible without having any rubbing issues front and rear, is this possible with the 25mm spacers?
Old Feb 2, 2015 | 09:05 AM
Hogbone's Avatar
For me, yes! I'm on a air ride system with stock 18s, oem control arms. I'm paranoid like a **** riding on my "lowest" ride hight because it's like cûñt hair close. I'll post up a few pic when I get home
Old Feb 2, 2015 | 11:19 AM
herrschaft's Avatar
A 25/30mm combo would probably be better. I had a 20/25 setup the wheels were close to the fenders. I can't remember if I had any rubbing issues in the front.
Old Feb 2, 2015 | 08:16 PM
Bucky727's Avatar
To be more specific I have the stock staggered 19s with 225s in the front, 245s in the rear and the stock sport suspension. I saw a youtube video of someone with my exact car, same wheels and tires with stock suspension, install 20mm front, 25mm rear and it looked extremely close. They looked close enough to possibly rub, but it was hard to tell. I want to be sure they will not rub under any circumstance. Any feedback specific to this setup would help me make sure I get it right the first time around. Thanks
Old Feb 2, 2015 | 09:49 PM
ScraggleRock's Avatar
If you're on stock suspension you won't rub. I have the 20/25 set up with those same tires and Im lowered an inch. I did have to roll my rears about 45 degrees cuz I would rub slightly around extreme turns, but that extra inch of height should keep that from happening.
Old Feb 2, 2015 | 10:21 PM
Bucky727's Avatar
If I were to add a set of Tein S-Tech springs which would lower it around 1 inch, it sounds like it would be ideal to maybe go 20mm all the way around without rolled fenders.
Old Feb 2, 2015 | 10:29 PM
Besides the fact that that would look dumb, I couldn't guarantee that would keep you from rubbing completely. 5mm is only 1/5 of an inch. As it is I'm wanting to go to 30R and 25F. When you lower your car the tires sink in, so the 20/25 rule no longer applies the same way. Just roll your fenders, its easy.
Old Feb 2, 2015 | 10:48 PM
herrschaft's Avatar
Here's an old pic. The car on the left has no spacers, the car on the right has 20mm Front and 25mm Rear. Both have 19" Rays. I can't remember if I was on S-Techs or coils at the time.
Old Feb 2, 2015 | 11:04 PM
Is that at race legal?
Old Feb 2, 2015 | 11:06 PM
herrschaft's Avatar
^Yep
Old Feb 2, 2015 | 11:19 PM
  #30
Bucky727's Avatar
Which part of the setup are you suggesting would look bad, the size of the spacers, not having rolled fenders, or both? (after installation of S-Tech springs)
