reverse light and camera
Old Nov 7, 2019 | 01:47 PM
John Mentzer's Avatar
35s
help i have no back up lights and the back up camera is not working
changed switch on transmission - did not work
Old Nov 7, 2019 | 04:09 PM
telcoman's Avatar
Veteran: Army
Prior to changing anything did you use your multimeter to check for voltage and ground. Check the fuse and test all points thru the wiring harness
http://www.nicoclub.com/FSM/G37/Sedan/2012/EXL.pdf
See page exl-75
Does the backup relay operate?
Old Nov 7, 2019 | 05:39 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If your dash gear indicator is showing reverse correctly then it's not the transmisson PNP switch.
Did everything work properly before and suddenly stopped working or has it NEVER worked properly?
Old Nov 7, 2019 | 07:06 PM
35s
it is a manual transmission so no gear indicator light .....suddenly stopped
Old Nov 7, 2019 | 07:08 PM
35s
so this is actually my sons car and i asked him to check the wiring and he hasn't done that yet but will now sinve he already spent money on a part that didn't fix the problem
thank you all for the tips so far wish us luck
Old Nov 18, 2020 | 11:37 AM
TShrader's Avatar
G35x
Did you find a solution for these not working, John? My 2008 G35x is doing the same exact thing. Appreciate your response. Tom
