Battery? Alternator? Fuel Pump? Help!
Old Mar 8, 2020 | 05:23 PM
JWeb6's Avatar
Matte Green G35 Coupe
Exclamation Battery? Alternator? Fuel Pump? Help!
So a couple days ago my 2006 G35 Coupe AT died on me. It took a couple turns of the key to start before work, and after work it wouldn't turn on. I tried to jump it, no luck. I used my OBD Sensor and it only threw code P0462, which is a common thing on here clearly. I don't think that would make my car die on me, but I did read somewhere it could cause a no start. But anyway, my service engine light, oil light, and battery light are all on, which is what makes me think my battery is shot. Could I just be dumb and need a new battery? Or is it a starter or alternator? Need help, thanks!
Old Mar 8, 2020 | 05:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Your terminology is incredibly vague, couple turns, cause a no start.
If the engine will NOT CRANK when you turn the key to START then you need to charge the battery and troubleshoot the starting system.
If the engine will crank but WILL NOT START then you need to start by adding 1 gallon of fresh gas, most people just run out of gas and the car dies, don't rely on your fuel gauge since you obviously have problems with that system and a P0462 code.
Old Mar 8, 2020 | 05:57 PM
JWeb6's Avatar
It doesn't crank, it sounds more like a grinding when I try to start it. I put two gallons of gas in it because I thought there as a shot i was out of gas, it still didn't turn on. I already tried jumping it too, which didn't work. It would crank once or twice while jumping it, but after trying it would just stop cranking.
Old Mar 8, 2020 | 06:03 PM
JWeb6's Avatar
Old Mar 8, 2020 | 06:32 PM
cleric670's Avatar
BANNED!!!
Post a video, that would help a lot. Put it on youtube and post the link here and it will automatically embed the video.
Old Mar 8, 2020 | 11:09 PM
MurdaG's Avatar
It's got 2 doors 😂
I'm willing to bet the starter is fried
Old Mar 9, 2020 | 03:25 AM
Scorpi0's Avatar
I love the taste of fried starters.
Rob G37S
Feb 27, 2020 07:10 PM
Nathan_Selby
Oct 18, 2019 02:30 PM
salena1973
May 23, 2018 04:21 PM
blaakcoffee
Jan 30, 2017 11:43 AM
PhonkyG35
Jul 27, 2016 11:59 AM
