Valve cover issues
Old May 19, 2021 | 06:03 PM
tttm1's Avatar
2 door coupe, mt6 Brembo edition, black on black
Valve cover issues
Hey guys, I’m old member, haven’t had may issues with my car but recently I had codes come up for random misfires. So on investigation and research I have found that my valve covers are leaking, on two of the spark plug tubes I can see the o ring is leaking, research tells me that I need to replace the covers as it’s a non repairable issue, any advice\suggestions?
Old May 27, 2021 | 08:43 AM
speedlimit's Avatar
Administrator Emeritus
G35
Hi!
Try posting in the tech forum that best matches your car.
Good luck!
Bob
Old May 27, 2021 | 11:32 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Lol @speedlimit you're sending him to a completely different website I'll edit that out for you.
Old May 27, 2021 | 11:33 AM
cleric670's Avatar
BANNED!!!
Ok as for your valve covers, yes the spark plug well tube seals are technically non-replaceable since they are molded into the plastic baffle. There are a couple threads on replacing just the well tube seals but it requires drilling/cutting on the valve cover and most folks just opt to buy new valve covers.
Old May 27, 2021 | 11:38 AM
speedlimit's Avatar
G35
Thanks!
That’s what happens when bouncing between 3 communities, too many tabs open.
Bob
TayeG35
Oct 20, 2017 09:52 AM
donutDrift
Nov 11, 2016 06:24 PM
Chris Movais
Jul 20, 2016 11:30 PM
frodos_4door
Apr 1, 2016 06:39 AM
