manual mode / tiptronic not working 05 g35 5at
Old Jul 1, 2021 | 09:27 AM
zolerg35's Avatar
2005 g35 coupe 5at. fbo lowered with bc coils on te37 18x9.5+28
When I put the gear selector into manual it will say m1 for a few seconds and then go right back to d or will just stay in d and never recognize I put it into manual mode anyone have any suggestions?
Old Jul 2, 2021 | 01:04 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Start by cleaning the transmission ground, top front of the timing chain cover are two green screws with a ring terminal under it. Remove and wire brush the bolt mating face and threads, the timing chain cover, and both sides of the ring terminal. Apply a very light layer of electrical anti-oxidation grease (not dielectric which is made to BLOCK electricity) then bolt it all back together.
If it's not the transmission ground it's probably the manumatic switches on the shifter, remove and spray clean with electrical contact cleaner that is PLASTIC SAFE, be sure to read the can to make sure it's safe for use on plastic.
Usually it's dirty MM switches but the ground is an easier fix and sometimes the issue.
Quann J
Aug 19, 2019 11:34 AM
