03 g35 vortec little power
Old Nov 5, 2021 | 09:48 PM
Ronbowman49's Avatar
Infiniti G 35 I think it’s fully loaded I just received it
Full vortec system not much power gain
03 g35 vortec
Old Nov 5, 2021 | 10:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably just using the big pulley, the little pulley has made over 700whp on one guy's build (very extreme build). 450 is a pretty common number though and that's the hard limit of the stock internals. If you're on the stock rods don't tune over 400whp unless you have a LOT of faith in your tuner though.
EDIT: There are 4 pulley sizes, 3.33" makes about 300whp, 3.25, 3.12, and the smallest is 2.87 that will pretty easily turn 400whp and has a LOT more potential.
Old Nov 11, 2021 | 11:03 AM
LexD's Avatar
After two dyno tuning sessions with the 3.12 pulley equipped my G is putting down 380whp on stock internals.
Throttle response is much improved, and overall drivability is better than ever. Highly recommend getting a pro to do the tuning if you have the means.
As alluded to above, was around low 300's whp with the 'big' 3.33 pulley.
Old Nov 13, 2021 | 02:24 PM
Thanks for that info I also need to know Two other things where to get the best tune and how much it cost I live in orange county and do you guys have a car show
Old Nov 13, 2021 | 05:54 PM
cleric670's Avatar
BANNED!!!
Call around to tuner shops and find out who does UpRev tunes for Nissan cars.
Old Nov 13, 2021 | 09:05 PM
Scorpi0's Avatar
I think @Seymore is somewhere in Socal
Old Nov 14, 2021 | 10:17 AM
cleric670's Avatar
BANNED!!!
You sure? I thought he was near Tacoma.
Old Nov 19, 2021 | 11:40 AM
Thank you for the good advice I will check it out
Old Nov 20, 2021 | 02:03 AM
Scorpi0's Avatar
I could be wrong
Old Nov 20, 2021 | 03:46 PM
That sounds great I’m definitely going to tune it with Uprev and injectors and 85 and fuel pump and the smaller pulley
g35shawty
Nov 23, 2021 04:26 AM
DannywiththeG
Nov 8, 2021 01:17 PM
Wang35hank
May 21, 2015 05:49 PM
Rymelol
May 15, 2013 07:18 PM
