Need help 2 DEAD cylinders
Old Aug 16, 2023 | 11:59 AM
tht.slow.35's Avatar
g35
So i swapped in a 40/60k motor from a jdm dealer swore it was good. Started up great no issues put full front end back together and boom timing rattle. Test drive. Flashin cel and misfiring/ backfires . Timings off check fuel good check spark good. Pull two coils in rear driverside no change to how car was idling (great) couldnt even tell it was running on 4 cylinders
I need help im not sure if its savable it runs and drives i really do not want to pull the motor again im not the best with a wrench so timing jobs are not my forte
Old Aug 16, 2023 | 12:04 PM
g35
Need help 2 dead cylinders
Old Aug 16, 2023 | 09:32 PM
Urbanengineer's Avatar
Maybe timing gasket issues. Definitely look into it more deeply.
Old Aug 17, 2023 | 10:52 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did you use only the long block of the donor engine and keep all your existing stuff like fuel injectors, coil packs, all sensors, etc?
What do the spark plugs look like?
Old Aug 17, 2023 | 10:55 AM
g35
Everything looks alright my plugs had 5k on them i used my coils and fuel rail
Old Aug 17, 2023 | 11:25 AM
cleric670's Avatar
BANNED!!!
What codes is it throwing?
Old Aug 17, 2023 | 12:02 PM
g35
Multiple cylinder misfire i pull two coils on the rear driver and it changes nothing to how its idling I believe it jumped time
Old Aug 17, 2023 | 02:18 PM
cleric670's Avatar
BANNED!!!
Are you sure you didn't accidentally swap a couple of the coil pack harness wires? It's really easy to do. I'd be really surprised if you jumped a tooth on the timing chain, that's just not really something that happens on these motors unless something like the chain tensioner or guide actually BREAKS.
Even with a broken chain tensioner (tips sometimes break off) it should still hold timing though.
After the engine swap did it run perfectly normal for a while? No check engine light?
Can you make a video and post it to youtube, then put the link here.
Old Aug 17, 2023 | 03:02 PM
g35
https://youtube.com/@omine1dj Only two videos on there
it has a noticeable timing chatter the video of it driving down the road has the cel flashing from a misfire
Old Aug 17, 2023 | 06:05 PM
cleric670's Avatar
BANNED!!!
Sounds like it's just running on 5 cylinders.
Was the car running normally prior to needing the new engine?
Pull all the plugs and inspect, see if they're all firing.
Old Aug 17, 2023 | 06:40 PM
g35
Its got spark on all 6 fuel on 6 but nothing when i pull the two plugs out while its running its running on 4 cyl
Old Aug 17, 2023 | 06:47 PM
cleric670's Avatar
BANNED!!!
So you verified that there is actually spark on those last two plugs? You saw it with your own eyes?
Old Aug 17, 2023 | 07:28 PM
g35
Yes ive done it all myself i kinda came to the conclusion that the issue with the two cylinders the timing chatter and backfiring i think its a safe bet that it broke a guide
Old Aug 18, 2023 | 11:50 AM
cleric670's Avatar
BANNED!!!
Well you could always remove the chain tensioner access cover and water pump access cover and look up inside the timing chain cover with one of those illuminated borescopes. They work fantastic for stuff like that.
951suspect
Feb 10, 2023 12:36 PM
CRW 23 23
Tuner & Dyno
Aug 12, 2022 11:46 AM
tatortot
Nov 2, 2016 12:03 AM
jivan balwant
Feb 11, 2016 04:51 PM
