G35 goes into limp mode
Old Oct 31, 2024 | 01:43 PM
Jimmer713's Avatar
Built twin turbo 2003 g35
Hi everyone!! This is my first g35 and also a turbo car. I bought this as a non running car. I’ve just got it to run good with the exception of a few things. What I’m most baffled by is….
when I’m driving it it will lose throttle control. I have to pull over and turn it off, then restart and it goes back to normal. I did replace throttle body and sensor. Any ideas of what it could be? Thanks in advance!!
Jimmer713
Old Nov 1, 2024 | 11:41 AM
jbarnett250's Avatar
DId you scan for codes? If it's going into a legit fail safe mode of some kind, there should be some code that would explain what sensor or system sent it there. Get a decent obd interface that can read transmission codes.
Old Nov 1, 2024 | 11:46 AM
Jimmer713's Avatar
G35 limp mode
I did put a scanner on it and could not come up with a code
Emik8
Sep 17, 2023 11:56 AM
Twoscoops
Aug 29, 2023 07:55 AM
Isela Herrejon
Feb 13, 2022 12:38 AM
Donr13
Sep 30, 2021 10:43 PM
