$ale - $78.88 3Ton Hydraulic Jack & 2 Stands
Old Sep 24, 2004 | 02:29 PM
G35PhatS4's Avatar
G SQUAD
Hey Guys...
Just a FYI... Sears Craftman has their 3 Ton Hydraulic Floor Jack AND two 3 Ton Jack Stands for $78.88 (Regular $120). This is the twist handle type Hydraulic... 3 or 4 pumps, and your car is up... The clearance is pretty low, and fits under my car fine (NOT lowered), and there's still a good 1" or so of clearance.
For those of you getting winter tire setup, this will definitely come in handy to swap out the rims/tires instead of using the little crank jack provided. Or if you plan on doing stuff to your car, changing oil, etc... might be a good investment!!
Very good investment IMO...
6MT DG Coupe | Prem | NAV | Aero | XM | Z-tube | Clears | 40%Huper | RH J5 Pro 19"
Old Sep 24, 2004 | 03:11 PM
NYCG35's Avatar
G SQUAD
Re: $ale - $78.88 3Ton Hydraulic Jack & 2 Stands
WHAT DO YOU WORK FOR SEARS TOO JAY.....LOL
LOL
I'm gonna wait actually ...they sell that plus the tire stops, jumper cables, lug wrench and creeper seat....all for $99,
So if you wait for maybe the thanksgiving or Xmas sales...you might get a better deal..
BUT that is a HOT price for that set!
Old Sep 25, 2004 | 12:42 AM
G35PhatS4's Avatar
G SQUAD
Well.. I got the UT Y-Pipe today from Mike... so I'm sure I'll make good use of the Hydraulic jack... [img]/w3timages/icons/wink.gif[/img]
Old Sep 25, 2004 | 06:08 AM
Speedoholic's Avatar
G (enie) FUNK ERA
Damn,
First the wheels, then the spoiler, now the y-pipe... Man you work fast...[img]/w3timages/icons/cool.gif[/img]
MY G-ENIE
Old Sep 25, 2004 | 02:44 PM
bigbadbooda's Avatar
G SQUAD
Jay, this is #50134, right?
I tried to get it this morning, but none available. Will try hicksville later.
What's the minimum height on this one?
Old Sep 25, 2004 | 03:07 PM
wizawuza's Avatar
babiephat, it fits under the front of the car?? No driving onto 2X4's or anything? Wow, that's pretty good.. looks like I need to replace my jack.
I need a creeper though, so I may have to wait for that other deal.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Sep 25, 2004 | 04:49 PM
G SQUAD
I just picked up this piece . . . it does NOT fit under the front of the car. I had to drive up onto the Rhino's to get it under.
BTW, am I missing something. I didn't use wood to get on the Rhinos. Is it because my driveway is sloped slightly?
Old Sep 25, 2004 | 07:56 PM
wizawuza's Avatar
I meant was the jack low profile enough that you didn't need to use ramps to get under the front of the car.
Driving on 2x4's just acts like a cheap small ramp. Raises the car enough to get a jack under there. Don't need the 2x4's to get onto a ramp.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
30% Huper
Old Sep 26, 2004 | 09:13 AM
G35PhatS4's Avatar
G SQUAD
No, I did not have to drive on blocks to get it to fit under my car... The clearance was tight, but when you give an extra twist ALL the way left after lowering it, the Jack drops 1/2" lower... I had no problems with the front or back. (My car is not lowered)
I attached a pix for reference...
Wizawuza... If you need to borrow the Jack, just let me know or PM me. I'm on your way home from Poughkeepsie anyways... [img]/w3timages/icons/wink.gif[/img]
Old Sep 26, 2004 | 11:20 AM
wizawuza's Avatar
Haha, thanks man.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
30% Huper
Old Sep 26, 2004 | 02:51 PM
G SQUAD
Thanks for the pic J!
What I actually meant by the front though was from under the bumper. There is a jacking point in the middle of the front of the car. This is the one I couldn't get to. I drove the car up on the ramps and then used the jack to lift.
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
toadfire
Sep 21, 2015 07:15 AM
