Maintenance / Repair Help
Old Sep 1, 2008 | 12:43 PM
  #241
Kris79's Avatar
battle froggy
the way i do it, grab emblem with finger nails and pull lol. googone the left over moldig tape call it a day drink a beer
Old Sep 1, 2008 | 12:49 PM
  #242
elayman's Avatar
^ lol the last step is the most important
Old Oct 12, 2008 | 03:15 AM
  #243
bythabay's Avatar
For those of you that I've worked with in the past, would you mind if I solicit a review for yelp?
http://www.yelp.com/biz/enthusiast-a...-san-francisco
Old Oct 14, 2008 | 02:40 AM
  #244
bmpnride's Avatar
Eugene, can I copy and paste the outstanding review I left for you on Yahoo??
Old Oct 14, 2008 | 04:43 AM
  #245
bythabay's Avatar
Sure, feel free.
Old Oct 30, 2008 | 04:27 PM
  #246
BurntRenolds's Avatar
Eugene, you're the best bro...I wish I was closer to the bay (from Toronto, Canada)but your DIY videos have helped me out big-time...thanks bro!
I was thinking about tackling a coolant flush...do you know of any DIY videos or is it easy enough if I follow the service manual???
I'm definitely due for bleeding my brake lines (how complicated is this to do myself?)
also what about flushing the brake fluid in the clutch (mines looks pretty nasty)...
Old Oct 30, 2008 | 04:49 PM
  #247
bythabay's Avatar
If you check the very first post, you will see all these items have DIY videos listed. Wow, is this the real Burt Renolds??
Old Oct 30, 2008 | 04:50 PM
  #248
bythabay's Avatar
nevermind, I thought this was a different post. just go to http://www.infiniticare.com and the videos will be listed.
Old Oct 30, 2008 | 06:39 PM
  #249
Thanks again bro...I just came from parts source looking for the pressure brake bleeding kit you have and ran into another guy looking for the same kit because of your posts...too funny...for every one guy who thanks you there are probably another 10 that use you vids...
Anyways I bought a different kit that draws the fluid from the caliper...I hope I don't screw it up...
Old Oct 30, 2008 | 10:11 PM
  #250
bythabay's Avatar
The adapter I used in the video is a universal adapter. You can buy the 1107 adapter now, it is a direct screw-on to the reservoir.
Old Dec 20, 2008 | 10:00 PM
  #251
yakswak's Avatar
I've got a problem. Car will not start. All I hear is a single "Click". Tried jumping it to no avail. Sat there for about 5min to try and charge it, no go. The problem happened this morning a few times...on a whim I put in the actual key and the car started. After that, it worked the entire afternoon around town.
Later this afternoon, I worked on installing a roof rack and thus had the doors opened for about 45min (dome lights on). Car will now not start at all. One click when I turn the ignition. Jump does not help. Please help! Is it my starter? (I hope not)
Old Dec 20, 2008 | 10:19 PM
  #252
dofu's Avatar
20 Year Member
Can you help me with my e-brake? I can't get it right... it's either too tight or not tight enough, and I think the handle side needs to be readjusted again too...
Your battery is just dead... you want to do a regular maintenance on the battery too... once any of the wells in your battery dry out, the battery won't hold a charge anymore and needs to be replaced. At that point, refilling the wells won't help.
Old Dec 20, 2008 | 10:38 PM
  #253
yakswak's Avatar
I sure hope so. It's weird though, inside lights work, all meters light up, head lights turn on, radio turns on, etc.
Old Dec 21, 2008 | 03:53 AM
  #254
gizsf's Avatar
Sounds like your battery is crapping out. Take it to Kragen or somewhere similar and they'll do a load test on it for free. Cold weather beats down the acual available amps that you need to start the car, and when it gets warmer, you get more. Thats the reason for CCA, cold cranking amps ratings on batteries. When the weathers like it's been lately, plenty of people find out their battery is shot.
Old Dec 21, 2008 | 12:45 PM
  #255
yakswak's Avatar
just took it to Kragen, battery is fine according to them. they said to bring the starter in, they could check it for me. now to look for a DIY on starters...
