when should the the tranny oil be changed??
sup guys
i was just wondering when the tranny oil should be changed? im thinking of doing it at 15K miles just cause i feel it needs to be but i went to the dealer and asked how many miles for it to be changed and they said every major service. what do you guys think 15K miles too early to do it?
I did my first one at 1.5k just to clean out the initial break in shavings.. and will be doing another one at 30k.. i believe 30k is the interval that you need to change it according to the manual.
I did mine at 60k...It wasn't that bad...but it should have been changed maybe a bit earlier. 30k-40k seems about right. I ordered a case of nissan matic-j fluid online..($95 for a case of 12) and took it to a good tranny shop to do a drain, clean out torque converter and pan for about $120 in labor/shop parts. All in all $215 for a really good tranny cleaning/flush.
6MT Coupe
Originally Posted by AL ASPIRATED
Its every 30k for auto and manuals.
My 06 maintenance manual says nothing about service intervals on the 6mt gearbox.
thanks guys for your help heres another question how about the rear diff same as tranny at 30k or eariler?
6MT Coupe
Originally Posted by bythabay
Yes, it is 30k for the differential also. Changing these gear lubes out with high quality synthetic lubes is a good idea in general. It's even better you change the fluids after about 3k which is when most of the break in for the tranny (6mt) and diff are complete. An initial change is supposed to have a dramatic effect on longevity of those components as I've read in several journals.
I've read many comments/experiences that the 6mt's servos do not agree with synth, meaning (100%) synth. Shifting became notchier and harder requiring even closer rev matching. Some synth blends and good 'ol dino base were the best to use and depending on the brand, (can't remember which brand right now) had the most sucessful improvements as far as the servos were concerned.
Originally Posted by 06CPV35
Agree with everything said except the synthethic choice for the 6mt box.
6MT Coupe
Okay...I don't doubt what you'r saying. And perhaps they were using the wrong type of synth.
The threads I had read pertained exclusively to the 6mt's shifting problems.
I'll go back in my archives to see which synth types didn't work well.
Thanx for your reference of what type you have had success with.
Two that come to mind that had worked well were GM Synchromesh FM (semi synth blend) and Redline MTL.
Now Amsoil SVG and Amsoil MTG I will make note of being very good choices, thanx to you.
yassy
Aug 9, 2015 07:31 PM
