Question about lowering springs
Old Apr 21, 2009 | 06:57 AM
Rhart's Avatar
Hey, im getting my Eibach Pro kit installed on my 05 coupe this wednesday. I was wondering if i will need a camber kit? I dont want any camber wear. I heard getting an alignment will do the trick?
If i do need a camber kit, which one should i get.
Also, is $160 a good price to get it installed?
Thanks guys.
Old Apr 21, 2009 | 11:51 AM
Kris79's Avatar
battle froggy
its not needed. but u willl get camber wear, but your stock car is set up to have neg camber. so even with it u will have some cambe rwear
160 is a good price for instal.
Old Apr 21, 2009 | 06:38 PM
Rhart's Avatar
but camber kit is needed to get it back to stock spec?
Old Apr 21, 2009 | 06:41 PM
Andy2434's Avatar
If you are concerned about early/abnormal tire wear, which most of us are, I would not hesitate to make good use of a good camber kit.
Old Apr 22, 2009 | 01:28 AM
Rhart's Avatar
what camber kit should i get? get both rear and front?
Old Apr 22, 2009 | 12:19 PM
G35Papa's Avatar
How much of a drop does that kit lower the coupe? If it's beyond an inch (1.5 or more) and you want to get back to OEM specs, Get both front and rear. If it's just an inch, just get the rear only.
You can get the Ichiba rear camber arms (same as SPC but cheaper price). This kit also comes with toe bolts. If you don't plan on going lower than 2.5" in the future, you can also pick up the SPC front a-arms. Ichiba also makes front a-arms but I have no experience with them.
Keep in mind that the G has no front camber adjustment and also factor in that you will need to get an alignment very soon after you install these kits.
Old Apr 22, 2009 | 03:04 PM
DEMoLITIoN's Avatar
You'll notice some understeer if you only get the rear set back to stock.
Old Apr 22, 2009 | 04:09 PM
Rhart's Avatar
from what i read, 1.1F and 1 R
Old Apr 22, 2009 | 05:00 PM
35gsleeper's Avatar
I have the Eibach ProKit on mine and I put the SPC rear camber but did not touch the front..barely notice any abnormal wear from front tires..Like Papa said that would be the best way to go..without killing urself to come up with more money to solve a minor problem..and do get that alignment
Old Apr 22, 2009 | 10:07 PM
Rhart's Avatar
thanks! that helps alot! i was going crazy figuring what setup i should do.
im goin to either get the ichiba or spc rear camber
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
