Anyone knows how to takeout the guage unit?
Old Dec 22, 2009 | 10:55 AM
kenempireex's Avatar
I need to get access to the gas meter needle, it went off the range.
https://g35driver.com/forums/g35-cou...ml#post4767771
Old Dec 23, 2009 | 02:15 PM
accordfreak's Avatar
got your pm. did you check out my diy on taking out the gauge cluster? it's not too hard.
https://g35driver.com/forums/body-in...56k-ha-no.html
Old Dec 23, 2009 | 03:43 PM
Thanks, accordfreak. Do I need to unhook the battery first?
Old Dec 23, 2009 | 03:48 PM
No. you might need to calibrate your fuel gauge when you take it apart. fill your tank to full first to see where the needle sits after you move it.
Old Dec 25, 2009 | 11:06 PM
bythabay's Avatar
I also have a DIY video on how to remove the cluster (see the sig)
Old Dec 27, 2009 | 11:22 PM
Thanks, accordfreak, bythebay. I for it fixed. However, I may need to calibrate the gauge. The handle is 1/8 of an inch over the "FULL" indicator. Do you guys know how to fix it?
Old Dec 28, 2009 | 12:18 AM
you have to move the needle clockwise past the stopper. once you have done that, move the needle until you feel resistance. Once you feel resistance, move the needle 1/8 of an inch more. Once you have done that, move the needle back counter clock wise back to the otherside of the stopper. let me know if that works.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Oregon13
Mar 1, 2016 12:06 AM
