grill help
Old Apr 19, 2011 | 12:00 AM
Bainy408's Avatar
grill help
either oem or aftermarket i ****ed mines up by sanding it.
Last edited by Grace; Apr 19, 2011 at 03:46 PM. Reason: removed f/s not allowed. post in the marketplace. kept the thread for information on sanding etc.
Old Apr 19, 2011 | 12:25 AM
TORETTO's Avatar
Pics of your grill?
I don't see how messed up it could have gotten by simply sanding it. When I painted mine, it looked like crap until it was finished.
If you could get pics, some people could give input as to whether you actually need a new one.
Old Apr 19, 2011 | 01:23 AM
Bainy408's Avatar
its sanded to the point where some places you can see the redish chrome finish. and other places its completely off. only thing this grill can be good for is to paint which i might do but last time i painted it, it had chips everywhere.
Old Apr 19, 2011 | 01:29 AM
TORETTO's Avatar
Might as well paint it.
How did you paint yours? I followed the DIY guide and mine lasted over a year with not a single chip.
IIRC the process was 2-3 layers primer, 4-6 layers paint, 2-3 layers clear coat.
Old Apr 19, 2011 | 01:34 AM
Bainy408's Avatar
Yeah thats what we did on my friends sedan it looks like its lasting pretty well. I'll probably most likely paint it. Any tips?
Old Apr 19, 2011 | 01:45 AM
TORETTO's Avatar
Just sand it down completely. And apply the primer, paint, and clear coat layers. With about 10-15 minutes of time between each layer.
Old Apr 19, 2011 | 01:54 AM
VincenzG35's Avatar
primer will fill anything in had the same issue on my friends TL grill i did 2 years ago and it still looks better than factory and not a single rock chip either
also a shift **** that has a button on the side cant be swapped with a **** that has the button on the front i have tried with the G37 **** and my 03 sedan. (now i have a g37 **** for no reason )
Old Apr 19, 2011 | 03:56 PM
Grace's Avatar
Avoiding potholes
Edited this thread becasue it had a f/s in it and it's only allowed in the Marketplace.
Kept it becasue it had useful info on fixing the grill.
OP this was your "get out of jail free" noob freebie.
Old Apr 19, 2011 | 04:24 PM
Skilled's Avatar
what grit sandpaper are you using? if its too low, youre just going to tear it up. its really hard to mess painting the grille up, because even if there are flaws after you paint. you can always go back and resand the area.
Picture Share
Feb 4, 2018 12:41 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
vQFamily
Sep 30, 2015 01:17 PM
itgogitrev
Sep 25, 2015 10:28 AM
