Transmission Cap?
Old Feb 21, 2006 | 04:16 PM
Sac2904's Avatar
Transmission Cap?
hi all,
I was looking for the transmission oil cap in my 04-G35 coupe. Do anyone know where it is? Yes, by asking this kind of question, you all could tell that I am a Pro! hehe, thanks
pd
Old Feb 21, 2006 | 04:48 PM
0MGHI2U's Avatar
yea it is behind the engine cover .. towards the back left if ur facing the car. (near the battery) u'll see it. u will need a 10mm socket and a extension.. just screw it off then it will pull out.. are u doin a tranny service. if ur just doin a drain and refill. just get 4 quarts.. thats all u need.. 17 quarts is if ur gonna flush it completely and do it... and the bottom of the trans there is a bolt i think its 19mm just drain it then add 3 quarts then start the car let it idle for about 2 mins . run it through the gears then while its running check the dip stick and add whatever the dipstick says.. if its full then leave it if its not then add some more.. but its ok to put the full 4 qts in it. i just did mine today. i goto a automotive school. so don't worry i know wat im doin haha lol.. but yea.. goodluck with that.. and if u got any questions let me know
oh yea MOST IMPORTANT.. YOU MUST i mean MUST USE THE NISSAN's TRANS FLUID. NEVER EVER USE OTHER BRANDS IT WILL AFFECT YOUR TRANSMISSION.
Old Feb 21, 2006 | 06:28 PM
Fini's Avatar
does that apply to MT? or only AT?
Old Feb 22, 2006 | 11:21 AM
Sac2904's Avatar
GThirtyFive4Me:
Thanks for your valuable information. The Transmission oil is a bit harder to spot compare to the engine oil. No, I am not doing anything with the oil service, just want to see where and what underneath my hood. I always thought the transmission oil would have a stick just like the engine oil, I guess not!
pd
Old Feb 22, 2006 | 05:45 PM
0MGHI2U's Avatar
the transmisson oil does have a stick i told u its behind the left side .. u see a **** nd its for some reason attatched with a 10mm bolt.. just loosen tht and pull out nd u can pull out the dipstick.
i did the tranny fluid for my 05 auto G coupe
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
vamarris
Sep 26, 2015 12:56 PM
