dropping my car
Old May 17, 2006 | 12:32 AM
thebayg35's Avatar
dropping my car
I just got some 20' Axis Matrix wheels on 255/285 tires.... pictures soon... i want to drop the car.. any advice?? Where should i go to do this?
Old May 17, 2006 | 01:55 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
any performance shop or wheel shop could drop your car for you.
if you are mechanically inclined, you could probably do it yourself.
if you are looking for recommendations, there is Z Car Garage and Scott Performance in Santa Clara.
Old May 17, 2006 | 02:13 AM
limeg35's Avatar
Send Josh "anotheraznguy" a PM, he work at Auto RnD and he is doing install on the side, actually in that shop just before business hour (7AM)...I have appointment this Friday with Josh for spring and rotors/pads...
https://g35driver.com/forums/northern-california/97491-suspension-work-south-bay.html
Old May 17, 2006 | 02:48 AM
kenempireex's Avatar
talking about drop, i actualy want to get a drop .5-1inch too, just for look. And i heard we need to match the right spring rating. I have the 19in package. What's a good set of springs? People mentioned that 04+ 350z spring will do the job.
Old May 18, 2006 | 12:36 AM
thebayg35's Avatar
i'm not sure what i need in order to drop it... and how much i should drop it without it starting to rub.... i have a 2005 g35 coupe on stock suspension with 20 inch axis 255/35/20ZR & 285/30/20ZR
Old May 18, 2006 | 02:23 AM
urban's Avatar
That is what I did, I have the 19" Volks and the Tien H tech off the 350Z cars and it dropped .8" front and rear, I was worried about camber but had it aligned today and was at negative 1.25 degrees all the way around and my toe was perfect.
Old May 18, 2006 | 01:55 PM
Ciabatta Burger's Avatar
anyone hear anything good about Tanabe springs?
Old May 18, 2006 | 07:45 PM
Andy2434's Avatar
Paul,
Excuse my noobish question . . . But is that amount of negative camber good, bad, safe, etc?
Old May 18, 2006 | 08:07 PM
urban's Avatar
Andy our cars come with slight negative camber from the manufacturer, I think this is around -.8 to -1 degree so my -1.25 negative should not be a major issue on the rears and even if it is the shop said I have more room to get it adjusted but he did not want to sacrifice the toe which is just as important. The fronts on the other hand are also at the same negative camber as my rears which again is not a major issue but he told me to keep an eye on it as there is no adjustment on the fronts and the evo8 arms are the only things that may be needed.
Old May 18, 2006 | 08:27 PM
Andy2434's Avatar
Thanks, Paul . . . Now, if only my new wheels and tires would show up. I haven't installed the Z H-Techs, yet. Just waiting . . . .
Old May 19, 2006 | 02:12 PM
limeg35's Avatar
Andy, if you dont want to install H-Techs yourself? I would whole heartly suggest bring you G35 to Josh, very reasonable price and of course, doing an excellent job as well...how much longer you have to wait for the wheels? I didnt want to bring it up in front of Mrs druing lunch
Old May 19, 2006 | 07:50 PM
SKYY-35's Avatar
Anyone here know much bout the Tokico D-spec shocks and the H-tech spring combo?? I just purchased them and now I'm waiting for my wheels. I won't get those til next wednesday tho.
Old May 20, 2006 | 12:13 AM
skeleton_cru's Avatar
Sedan
Check into Gruppe-S in Hayward.
Old May 20, 2006 | 12:45 AM
anotheraznguy's Avatar
im always ready and willing to help anyone out =)
also can get u parts as well..
Old May 20, 2006 | 12:59 AM
LightsOutG35's Avatar
All depends on your budget, if you want to go top notch, go with HKS Coil Overs, however if you don't want to spend nearly as much but still want a nice drop, I recommend Eibach Pro Kit Lowering Springs, great reviews. 1.1 inch drop in the front and 1.0 inch drop in the rear.
