NorthWest Serving AK, ID, OR, WA
Test Pipes/HFC's and Washington Emissions
Old Nov 4, 2006 | 07:39 AM
Jining's Avatar
So I dont really know much about emissions here in Washington, but im guessing it isnt like Florida where everything is cool. I assume if I got test pipes, I would have to swap them for my stock cats when emissions time came up? Any estimate on how long/hard it is to swap testpipes/cats?
I was thinking of getting the Fast Intentions HFC's but.. test pipes are so much cheaper....so... Hmmm
Thanks for any help!
Old Nov 4, 2006 | 11:48 AM
first350's Avatar
HFC should let you pass emissions...TP's will not. It took me about 4 hrs on my own to swap Cats. (*I have a 350z...not sure how much different it is)
-Peter
Old Nov 4, 2006 | 11:54 AM
ttrank's Avatar
Grocery getter
HF cats should pass, test pipes will fail.
Old Nov 4, 2006 | 01:07 PM
redlude97's Avatar
In washington, do they actually run you through the smog test, or do they just plug into your OBD-II slot to check for codes and emission failures. I know in oregon thats all they do for newer models, so if you get an 02 simulator and don't throw any codes then you can pass. I passed with a test pipe in my prelude because I wasn't throwing any codes at the time
Old Nov 4, 2006 | 05:44 PM
Soopa G's Avatar
also, if you have an 03 you won't have to worry about it until the cars is 5 years old, they don't require smog test until 5 years
Old Nov 4, 2006 | 07:55 PM
Jining's Avatar
Anyone know the answer to that? Whats the OBD-II? so I could pass with test pipes perhaps...
Old Nov 4, 2006 | 10:43 PM
stealthninja296's Avatar
Yes, Washington uses the OBD-II connection test.
Old Nov 4, 2006 | 10:46 PM
MixturePinoy's Avatar
My homeboy with a 02 S2K passed with a 02 simulator.. He's running custom full exhaust with SC. I'll get more info from him.
Old Nov 5, 2006 | 03:17 AM
Jining's Avatar
cool keep me posted! Thanks!
Old Nov 6, 2006 | 12:58 AM
Jining's Avatar
Hmmmm... do you think if it smells strongly of gas they will call me out on it? Also, when you swapped your cats, It can just be done with 2 jackstands right?
Old Nov 17, 2006 | 08:04 PM
bobshuai's Avatar
I heard both answer from many different friends, some said crowford HFC will pass smog and some told me crowford HFC won't pass smog in California with G35. Can anyone input me some more information on that because I want to purhcase HFC but I don't want to mess with smog later on.
Old Nov 17, 2006 | 09:39 PM
redlude97's Avatar
Not sure, but this is the northwest section. I'm sure smog in Cali is different. HFC's probably won't pass visual if they notice them though since I don't think they have a CARB number
Old Nov 19, 2006 | 06:26 PM
shdowflare's Avatar
Emissions in MD
Gang,
I'm getting ready to get either the Crawford or Fast Intentions HFC's and wanted to see if anyone knows whether they'll pass the emissions test here in Maryland. We use the OBDII method, where the tester just plugs into the car and checks it out. Oh, I should also mention that I'll be putting the Crawford headers on too.
Any help is appreciated.
Thanks,
B
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
Visionnn
Oct 3, 2015 05:16 AM
