NorthWest Serving AK, ID, OR, WA
Clutch Issues :(
Old Jun 3, 2009 | 07:31 PM
Silver Sedan's Avatar
Clutch Issues :(
Like many other owners, I have been experiencing issues with my clutch only returning half way back on warm days...such as today! Many members posted the link to changing clutch fluids, which I just completed with DOT 3 fluid. The issue is still happening, and I am wondering if using DOT 4 would help at all?
The local Schuck's Auto Supply only had DOT 3...does anyone know where you can buy DOT 4 fluid locally (Seattle/Bellevue area)?
Thanks in advance for your ideas and help!
Old Jun 3, 2009 | 11:52 PM
djSLiM's Avatar
autozone used to have the valvoline dot 4 but i don't remember if they still do or not anymore. if you're in to spirited driving it would be in your best interest to get some performance fluid like the motul rbf 600. i use that in my vw and it stands up to heat and pressure extremely well.
Old Jun 4, 2009 | 12:16 AM
Thanks djSLIM. I will see what I can find. Its so hard to find decent auto parts, fluids, etc anymore. All you can find off the shelf are the basics.
Old Jun 4, 2009 | 01:01 AM
djSLiM's Avatar
there's a vw tuner in redmond called achtuning(.com) that sells the motul. clicky
Old Jun 4, 2009 | 01:16 PM
Soopa G's Avatar
you can get the Motul RBF600 at most any motorcycle shop....
You may also want to replace the clutch line with a steel braided one if the fluid doesn't help
Old Jun 4, 2009 | 02:19 PM
1SlowSedan's Avatar
if DOT 4 doesn't solve your problems, it might be the master slave cylinder.
Old Jun 5, 2009 | 12:07 AM
djSLiM's Avatar
Originally Posted by 1SlowG35Sedan
if DOT 4 doesn't solve your problems, it might be the master OR slave cylinder.
fixed for accuracy
Old Jun 5, 2009 | 12:18 AM
Jeff92se's Avatar
Red Card Crew
napa usually has dot 4. ie.. like valvoline synthetic
Old Jun 17, 2009 | 07:13 PM
I ordered some Motul RBF600, and should be at my house tomorrow. Hopefully that does the trick.
Thanks for all of the input!
Old Jul 10, 2009 | 09:07 PM
Update
Finally got a hot day here in Washington, and did NOT have any issues with my clutch pedal. So far the upgrade to the Motul RBF600 clutch fluid has helped!
Hope this solves my issues!
Old Jul 12, 2009 | 08:01 PM
djSLiM's Avatar
sweet
Old Aug 10, 2009 | 02:05 PM
G35Hokie's Avatar
How much fluid do I need to flush and fill? 500ml or more?
Old Aug 11, 2009 | 09:54 PM
Jining's Avatar
2 of those 500ml bottles should do it.
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
NemesisGee
Aug 11, 2015 07:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
