FS: Sidi Vertigo Air perforated riding boots size-10
Old Nov 24, 2010 | 08:28 PM
jspec86's Avatar
Used for less than two seasons of mild riding, theyre in great shape
They are size 10, but fit like a size 9. I wear size 9 shoes, these boots fit a bit small
-The Vertigo series of boots are the only race boots to offer a patented Tecno VR adjustable calf system designed to accommodate calves of up to 16.5 inches in circumference 11 inches above the bottom of their heel in a clean, supportive and protective design. With a simple adjustment of the Tecno **** the internal monofilament line will evenly close and wrap the boot around the riders calf in micro adjustments for a perfect fit.
-Three stage, shock absorbing heel cup molded in three different densities of plastic is one element that sets the Vertigo series apart from all other sport boots. This system offers a built in shock absorbing range of 3mm. The heel cups internal area is also fully lined with impact resistant thousand-air cell memory foam for and extra level of comfort and protection.
-Each Vertigo series boot is lined throughout with lightweight perforated Teflon treated fabric in order to allow moisture to breath out to the Lorica outer and dry quickly with no mould build up in the long term.
-Gear change pad is molded of Dupont Techno-polymers, which ensure that the plastics qualities will not change in high or low temperatures.
-A new dual compound, lightweight, non-slip sole for maximum comfort and safety.
-Plastic insole and inner shank for comfort, durability and protection. The insole features a removable arch support and will never lose its dynamic characteristics, even after months of intense use; it is water resistant and is designed to withstand high footpeg pressures.
-The inner ankle area of all Vertigo series boots are fully lined with Sidi's own formula of closed thousand-air cell memory foam.
-Every bolt on components of each Vertigo boot is available separately. Riders can change the various components to replace items that have worn or have been damaged in a crash.
-Malleolus guard on the outer edge of each boot to further protect the small and vulnerable foot bones.
-The Malleolus area of each Vertigo series boot also features a snap-lock vent panel. Choose between an open maximum airflow position or a closed position to block air and moisture from entering the boot.
looking to get $200 + shipping
fT-z33wor is my username on my350z.com, here's a link to my thread made in the exhaust section with BOTH my usernames on the paper
http://my350z.com/forum/exhaust/5072...ml#post8801667
KruZZe
Feb 27, 2023 05:04 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
