Ohio representation?
Old Jun 23, 2009 | 11:33 AM
  #1891
BuckeyeG's Avatar
Originally Posted by BrianlG35C
With my built motor and TT setup, I go around 2K miles for synthetic change.
Yea you got alot more in your motor then I do. Plus we use Amsoil and they say to change it once a year or like 15k but we figured 2 times a year would be safe.
Old Jun 23, 2009 | 11:34 AM
  #1892
cdubel01's Avatar
CLUB MODERATOR
Be VERY careful.....Hate to see that thing of beauty hurt....
Old Jun 23, 2009 | 11:51 AM
  #1893
BrianlG35C's Avatar
Ohio G Club Member
I've used Royal Purple, Amsoil, Castrol and now Rotella T-Syn. Yeah since my build, my shop recommends I change it every 2500-3K, even with synthetic. Here's a chart that was done on by a knowledgeable guy on my350z.
Here's a comparison chart I've made to highlight oils whose results, when averaged according to engine wear for every 1000 miles of use, stand out as a significant statistical difference from the mean. I divided the engine wear for each metal by the mileage for each and every UOA I have, and then multiplied that by 1000 to generate a ppm for every 1000 miles driven. I then found the average for each wear metal (iron, copper, etc..) for all the UOA results and the standard deviation of each wear metal result from the average. This chart shows the average wear for each current oil tested in terms of ppm/1000 miles. The cells with a green background are better than one standard deviation from the average. The cells with a red background are worse than one standard deviation from the average. The average and SD, remember, is calculated from ALL the samples I have from the VQ. The average wear characteristics of some oils used in the VQ which are no longer in production I have also included in a separate table.
The interesting thing is to note which oils are statistically significant in terms of better or worse wear from the universal average for each wear metal. It would be nice to have multiple samples from some of these oils before the manufacturer changes formulas again.
Old Jun 23, 2009 | 12:57 PM
  #1894
BuckeyeG's Avatar
I only put about 4k on in 6 months so its not to bad.
Old Jun 23, 2009 | 03:54 PM
  #1895
Dal35's Avatar
TuningWerks Competition
hrmm... what weight? 10/30?
Old Jun 23, 2009 | 04:14 PM
  #1896
BuckeyeG's Avatar
We use 0-W30. I got a guy local that gives me a pretty good deal on it and an Amsoil filter.
Old Jun 25, 2009 | 12:43 AM
  #1897
davie's Avatar
I am about to buy a turbonetics ST kit for my G in the next week, Does anyone around the cincnnati area know of a shop that will dyno and tune my car? Also I need to buy a utec or something, any suggestions?
Old Jun 25, 2009 | 08:53 AM
  #1898
Dal35's Avatar
i dont think there are any good shops in Cincy.. You will have to come to IPS or Slowmotion in Columbus to properly tune your car. Yes, utec ecu you need to get for your car. I am running the exact same set up.
Old Jun 25, 2009 | 01:52 PM
  #1899
moete87's Avatar
Ohio G Club Member
There is TD Performance here in Cincinnati but I would go to the better shops that Dal had mentioned above.
Old Jun 25, 2009 | 02:38 PM
  #1900
davie's Avatar
If I have a friend install the turbo, am I able to drive the car to get it tuned and dynoed? Also how much is it to get it tuned and dynoed at IPS?
Old Jun 25, 2009 | 02:54 PM
  #1901
Dal35's Avatar
You can call them up and ask them. I dont go to IPS.
Old Jun 25, 2009 | 03:33 PM
  #1902
davie's Avatar
Where did you get yours tuned?
Old Jun 25, 2009 | 03:40 PM
  #1903
IrockAG35's Avatar
Ohio G Club moderator
its best to trailer..for a mere 50-60 dollars its worth the money instead of blowing an engine. while i was in the area 2 months ago i got a quote for a full tune and dyno of around 500.00
Old Jun 25, 2009 | 04:24 PM
  #1904
Evil Wayzz's Avatar
WU'ts good Ohio people. How is it going up their.
Old Jun 25, 2009 | 04:29 PM
  #1905
Dal35's Avatar
My engine work is done at Slowmotion. Link is in my signature.
