Look What I Got Today!
Old Mar 15, 2010 | 09:16 AM
  #391
g-adabout's Avatar
I understood that they were different, but I dont see the gains in going with the more expensive set. Could you elaborate Arnab?
Old Mar 15, 2010 | 11:59 AM
  #392
Rambo's Avatar
Well, the SPLs are shim based adjustment and they also put the adjustment bolts in tension(stress along the long axis of the bolt) instead of being in shear(stress across the diameter of the bolt). This will allow for greater lateral loading of the entire conrol arm. They are also machined out of a solid block instead of welding(induces much more stress and bending into the part). Also, shims are usually a better way(if designed properly) to adjust things than sliding grooves or slots.
The SPLs are also just "beefier" and have pivot bearings instead of shaft bushings like the SPCs. This allows for a litte more natual movement and allows for slight miss alignment with out any negative effects on the system.
There is nothing wrong with SPC(I am actually looking into these as well) but the SPL arms are just a better design from an engineering standpoint.
correct me if I am wrong. But these are my thoughts...
hope this helps.
Old Mar 15, 2010 | 02:53 PM
  #393
stradaONE8's Avatar
Rambo nailed it. SPCs are very solid pieces too. I am definitely considering them as well. The SPLs are as Rambo said, better engineered for track duty and a bit more solid overall. Honestly speaking the SPCs are perfectly fine for everyday driving and tracking the SPLs just give you that extra degree of engineering for marginally improved performance. Not sure if it's worth the extra $225 yet based on my needs. But I only buy things once and Id rather just get them now if I anticipate I may need it in the future.
Old Mar 15, 2010 | 03:13 PM
  #394
g-adabout's Avatar
Great explination Guys! I do see the difference now thanks to the pics...and I agree that I couldnt justify the price difference for my car. If you guys get them, I would love to see them in person to see the engineering superiority.
Old Mar 15, 2010 | 08:23 PM
  #395
Procustom_G35's Avatar
Originally Posted by Procustom_G35
LoOk what i got today!!
Motordyne 5/16 copper isothermal plenum spacer (oil filter came with the purchase! =])
Got the driver side valve cover because it was leaking oil and im out of warranty lol
DC-Sports Ceramic Headers
Im not sure when i will be installing these parts yet. Ill def post up pics of the installs.
MoRe to come...
ok guys, im wondering if i should really install these headers or not because ive been lookin at more vids & found that aftermarket headers produce more rasp than i thought it would, especially if i run resonated or non resonated test pipes. im not really a big fan of rasp, but i want more hp gains without FI, what do you guys think??
Old Mar 15, 2010 | 08:28 PM
  #396
carsontl's Avatar
I have been reading that headers do not make that much difference on our machines
Old Mar 15, 2010 | 08:34 PM
  #397
stradaONE8's Avatar
Here...jb's proper NA build. Look at what he's done and the final power results. IMO a NA build on our car is more about motor response than pure power. If you want #s, there's no way around FI on our cars. If you want a bit more power and a much more freely revving engine, you need to do a lot more than bolt-ons. Our cars tend to derive very little from basic bolt-ons.
You already have the spacer, I recommend a tried and true exhaust (HKS true dual, Motordyne, etc). Then you get sound and can control rasp easily with a proper choice. Aside from that, nothing basic bolt-on wise really gets you much more than marginal power. Yes the header will obviously make more than now, but for the money it's not worth it until you exhaust other options...
Old Mar 15, 2010 | 08:51 PM
  #398
BuckeyeG's Avatar
Or you could try Fast Intenions exhaust they have some really good resonators to cut down rasp.
Old Mar 15, 2010 | 08:55 PM
  #399
O HELLA OEM's Avatar
hks+MD 5/16 spacer(thanks to BEN) = Sick as$ sound and power increase lol
Old Mar 15, 2010 | 09:10 PM
  #400
^cool thanks for the info Arnab. jb's build is very nice, but im not lookin to do anything major. Seeing that our cars do not do much with these upgrades, i dont think i will install them unless i get an exhaust system. I've been lookin into the MD shockwave V2.
Old Mar 15, 2010 | 09:46 PM
  #401
carsontl's Avatar
i've been looking into the MD shockwave as well, but I might steer towards an HKS if I can find it for cheap
Old Mar 15, 2010 | 09:49 PM
  #402
^get HKS you wont regret it!
Me, Jeremy and Dal all have it.. lol
im NA with HKS, Jeremy has a Turbonetics with HKS, and Dal has Greddy Twins with
HKS
Old Mar 15, 2010 | 10:08 PM
  #403
g-adabout's Avatar
Hks ftw!
Old Mar 15, 2010 | 10:48 PM
  #404
carsontl's Avatar
i recently bought some fast intentions resonated test pipes, the guy I bought them off of said there's a guy near him that's selling HKS true duals for cheap, so I'm trying to find more information on that one.
Old Mar 15, 2010 | 10:50 PM
  #405
^post pics of you can, dont be fooled by hks replicas
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
