Throttle Body Issue Please Help!!
My car is not idling correctly after i changed out my plenum. It starts runs to 3-4k then goes down to 300-400RPM and putts out.
Any suggestions? Was wondering if I could borrow a throttle body from anyone to swap it out to see if that is the issue.
Let me know!! Thanks for any help!!
Please send this to me. Do you have the throttle reset as well?
What I have done tonight:
1. Removed and cleaned the throttle body. No major build up was present.It moved freely with a slight spring back.
2. Removed and cleaned the MAF sensor. No major build up, if any was present.
3. Cleaned all connectors.
4. Removed battery connection. I am going to let it sit overnight and I will reset the ECU and throttle position tomorrow.
If anyone has any other suggestions please let me know.
