Dilemma with my rear shocks!!
It's only about a mile from QSL which usually ends up being the start point for several of the meets. That works out well for me.
I don't see how they'd need to break the knuckle to get the bolt off. I did shocks on my sedan over the summer and I had them both out and swapped in 30 mins, just PB breaker and a pipe over the rachet got them off easily. Cut the bolt and call it a day.
If you're not in a hurry, soak the nuts down with PB blaster once a week for a few weeks. When spring rolls around, they should come off pretty easily. My sedan was a winter car for 2 years, so the hardware saw a little salt and had a little corrosion on them.
Still, I was able to cut the hardware off my 1990 4Runner (has seen a LOT of mud and salt) without having to resort to breaking off other parts of the suspension. Sounds like these guys are trying to bone you.
rezendvous420
May 31, 2020 01:26 PM
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
I'll probably hit you up closer to spring! Where do you live?!
