Jack Stands and the G
Old Aug 2, 2006 | 11:24 PM
trey.hutcheson's Avatar
I'll set the price right now. $50, plus shipping, for the set of four.
Old Aug 3, 2006 | 09:30 AM
rcdash's Avatar
under the car, at the jack points and just inside the groove, is a raised elongated portion that fits the jackstand profile quite well. I've always used those - why do you need to use adapters?
Old Aug 3, 2006 | 09:37 AM
OH6 G35's Avatar
Just didn't want to take a chance....at the pinch welds.
The adapters are used to contact more surface area (of the body).
Old Aug 3, 2006 | 10:30 AM
jameyb's Avatar
Looks great and I would buy a set of 4 adaptors (or whatever you call them) in a heartbeat if you are interested in making more and selling them. I bet you will find that there is a lot of interest.
I, like others, have searched for something similar with no luck. I currently use the points described by rcdash with folded rags between the frame and stand.
Old Aug 6, 2006 | 01:32 PM
OH6 G35's Avatar
Some additional DIY Info...
Attached Thumbnails Jack Stands and the G-01.jpg   Jack Stands and the G-02.jpg   Jack Stands and the G-03.jpg
Old Aug 6, 2006 | 01:33 PM
OH6 G35's Avatar
...continued.
Attached Thumbnails Jack Stands and the G-04.jpg   Jack Stands and the G-05.jpg   Jack Stands and the G-06.jpg
Old Aug 6, 2006 | 01:43 PM
MD_V35's Avatar
I would buy these too. You should make them, i think you will find alot of intrests to buy them amongst the DIYers out there.
Old Aug 6, 2006 | 10:51 PM
imalazeeass's Avatar
Is there a central jacking point from the front like your last pic? I have aftermarket sideskirts and cant really go from the side.
*edit i see it on your 2nd to last pic, where is the point you're jacking up on?
Old Aug 7, 2006 | 12:20 AM
IPon6MT's Avatar
sweet.. build these... I'll buy a set.. and im sure you'll get alot of interest.
Old Aug 7, 2006 | 01:14 AM
OH6 G35's Avatar
There is a central jack point (shown in the diagram) but you need to raise the G, or at least one side, in order to get at it (with a "regular" Floor Jack. This location is right behind the "undercover". The only other alternatives are to either use a lift, a pit or a extended low-profile jack (expensive) !!
Old Aug 7, 2006 | 01:27 AM
OH6 G35's Avatar
...oops ! I forgot to include the diagram.
My Bad !!
Old Aug 7, 2006 | 03:26 AM
id buy one too if u made some
Old Aug 7, 2006 | 08:18 PM
Dan_K's Avatar
Where in socal are you?
Old Aug 7, 2006 | 08:23 PM
OH6 G35's Avatar
South Bay area...
Old Aug 7, 2006 | 09:41 PM
  #30
Hugen35's Avatar
Trendsetter
So?? what is to happen .. if one of these pinch welds were to be bend?
