275/30-19 in front w/ sum GREX brakes
fit a 275/30-19 on a 19x10 in front on my G today...ZERO rubbing and SUPER flush
+1 what are you using in the rear?
fwiw, if you're going with a 30 profile, you can actually fit a 285/30/20...i did, lol.
for the n00bs:
Tire 1 - 255/35R19
Tire 2 - 275/30R19
Section Width: 10.03 in 255 mm
Section Width: 10.82 in 275 mm
Rim Diameter: - -
Rim Diameter: 19 in 482.6 mm
Rim Width Range:
Rim Width Range: 9.5 - 10 in
Rim Width Range: 9.5 - 11 in
Overall Diameter: - -
Overall Diameter: 26.02 in 660.90 mm
Overall Diameter: 25.49 in 647.44 mm
Sidewall Height: - -
Sidewall Height: 3.51 in 89.154 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: - -
Radius: 13.01 in 330.45 mm
Radius: 12.74 in 323.59 mm
Circumference: - -
Circumference: 81.74 in 2076.1 mm
Circumference: 80.07 in 2033.7 mm
Revs per Mile: -
Revs per Mile: 799.3
Revs per Mile: 816.0
for the n00bs:
Tire 1 - 255/35R19
Tire 2 - 275/30R19
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
Awsome breakdown but I would like to put a caveat to it. Even with the same profile there can be differances between tire manufactures. I found this out the hard way going from Nitto to Toyo's. The Nitto's were much "thinner" compared to the Toyo's even running the same profiles.
for the n00bs:
Tire 1 - 255/35R19
Tire 2 - 275/30R19
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
for the n00bs:
Tire 1 - 255/35R19
Tire 2 - 275/30R19
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
Jeff T
Sep 30, 2015 02:00 PM
