Engine Bay Pics*Post here*
Old May 20, 2012 | 06:09 PM
  #2506
Elmecano's Avatar
this how look my engine bay not perfect but I like the result
Old May 20, 2012 | 06:54 PM
  #2507
slvrg05's Avatar
this is looking good BigVicG35
Are the valve covers powder coated ?
Old May 20, 2012 | 11:59 PM
  #2508
JDM_Cain's Avatar
Finally got around to posting pictures of the work done at Technosquare. Special thanks to Howard, owner of Technosquare, Randy, and Marty for their help with this project!
Polished Timing Chain Cover
Polished Alternator
Polished Power Steering Pump
Polished Misc Brackets and Hex Bolts
Earls Clamps and SS Hoses
Before engine bay shot
Old Timing Chain Cover
Howard cleaning up the new cover.
Old alternator. Fugly..
Nice, polished Alternator casing
Randy assembling the Alternator
New Alternator, much, much better
Randy has to now figure out how to swap the Power Steering housing/internals.
All put back together....what a difference. Pictures don't do it justice...
Old May 21, 2012 | 06:37 AM
  #2509
RicoG35x's Avatar
simply FREAKIN' BEAUTIFUL!!!!
Old May 21, 2012 | 08:05 AM
  #2510
alfhasg35's Avatar
Lookin great Chris..!!
Old May 21, 2012 | 06:02 PM
  #2511
HotRodG35's Avatar
Chris looking clean and smooth.
Guess Randy figured out the PS pump internals, fairly simple to swap.
Keep up the great work.
Old May 23, 2012 | 01:16 AM
  #2512
JDM_Cain's Avatar
What's up Alex! Thank you Sir! Your bay is also off the hook man!
Yeah, Randy figured it out eventually. He'd done swaps before so had experience....
Old May 27, 2012 | 09:19 PM
  #2513
Heist.'s Avatar
just did a tuck on my buddys coupe.
should have everything polished soon.
Old May 31, 2012 | 02:24 AM
  #2514
P10 WRC's Avatar
Hello everyone. Quick question for the tuck of the driver side harness in the fender. I have got my holes cut and it seems like every wire is long enough except the headlight harness. It is about 6 inches too short. Am I okay extending these wires using butt connectors or is there some other method you guys recommend for extending the wires. Thanks,
Marty
Old May 31, 2012 | 03:05 AM
  #2515
k67p67's Avatar
Marty
Butt splicing will work although soldering is far more reliable.
Old May 31, 2012 | 12:16 PM
  #2516
NFSP G35's Avatar
? = 2B || !2B
Butt connector is usually ok for ground wires, but for anything else you should really solder, coat with liquid electrical tape, and heatshrink.
Old May 31, 2012 | 12:19 PM
  #2517
NFSP G35's Avatar
? = 2B || !2B
Oh, I just remembered, did you take the harness connector on the headlight itself off of the little metal clip that holds it on the housing? That will net you a few inches
Old May 31, 2012 | 03:14 PM
  #2518
P10 WRC's Avatar
I used solder and heat shrink on it. Everything is good to go now
Old Jun 6, 2012 | 06:23 PM
  #2519
SDGenius's Avatar
snap from WEKFEST LA
Old Jun 6, 2012 | 07:37 PM
  #2520
Carnage's Avatar
Wow very very nice bays in this thread. Here is mine, its um a work in progress, lol.
