Engine Bay Pics*Post here*
Old Jan 8, 2010 | 10:54 PM
  #1756
OCG35's Avatar
^^^ thank you though
Old Jan 8, 2010 | 10:55 PM
  #1757
bigc's Avatar
Wings Nation
ok, take apart your instrument panel, cut a little picture that looks like a hood propped open, then put the LED behind it
Old Jan 9, 2010 | 09:50 AM
  #1758
GreenGoblin's Avatar
The goblin resurrection
My oem sensor went right in the junk bin, along with tons of other stuff.
Old Jan 9, 2010 | 11:03 AM
  #1759
DG_coupe's Avatar
^so you don't need that safety latch sensor? is it safe to literally cut it off?
Old Jan 9, 2010 | 11:22 AM
  #1760
SxExCx's Avatar
^the only difference is that the horn wont honk if someone tries to open the hood while your car is locked.
All you have to do is unplug it and unbolt the bracket from the fender.
Old Jan 9, 2010 | 11:23 AM
  #1761
SxExCx's Avatar
Originally Posted by OCG35
but I want it on my dash/instrument cluster... iow I wish it was and OEM warning light (like I said before Sean suggested I was whining)...
You know I was kidding...right?
Old Jan 9, 2010 | 12:08 PM
  #1762
OCG35's Avatar
yes - I was too... smart @ss to smart @ss
Old Jan 9, 2010 | 12:56 PM
  #1763
DG_coupe's Avatar
Nice thanks for the info
Old Jan 9, 2010 | 03:16 PM
  #1764
G35Papa's Avatar
Question
There is a bunch of grounding wires that connect to one point under the battery compartment onto the fender well. See red arrows in the pic below. For the guys that tucked these wires, did you extend all those wires or re-ground those wires elsewhere? If you regrounded them, where did you do so?
Thanks!
Old Jan 9, 2010 | 04:04 PM
  #1765
k67p67's Avatar
You can do whatever you want with any of the grounding wires. Cut, shorten, lengthen, reroute, consolidate, doesn't matter.
Old Jan 9, 2010 | 04:16 PM
  #1766
G35Papa's Avatar
Thank you
Old Jan 9, 2010 | 07:12 PM
  #1767
hyperlite21's Avatar
Originally Posted by G35papa
Thank you
make sure you do re ground all of them tho, and tight, i had a loose ground in that compartment and my at check light came on...didnt know it was a loose ground till $100 later at the dealership haha
Old Jan 9, 2010 | 09:53 PM
  #1768
G35Papa's Avatar
^Thanks for that.
I winded up finding another mounting point on the fender well, on the passenger side and just bolted it back up. I had to extend the grounds on the drivers side though. It's all buttoned up now but I'll check it again once I jump start my car lol Battery is dead
Thanks again for the pics and tips. They helped out
Old Jan 9, 2010 | 10:53 PM
  #1769
Dranom's Avatar
^post pics!
Old Jan 9, 2010 | 11:06 PM
  #1770
G35Papa's Avatar
NO! lol
I'll post a couple of the sides but not the whole bay. I want to finally finish it (I hope) then I'll get full pics up. I guess I should post some pics though cause this is a pic thread lol
