Engine Bay Pics*Post here*
Old Jan 7, 2010 | 09:28 PM
  #1726
xXHotelCrazyXx's Avatar
Originally Posted by SxExCx
+1
Danny, are you sleep-posting again?
+2, more info on this?
Old Jan 8, 2010 | 01:01 AM
  #1727
G35Papa's Avatar
Anyone care to share any tips on the harnesess coming over the fender wells? (headlights, airbag sensor...etc). I'm going to tuck those this weekend if I can sort it all out
Thanks!
Old Jan 8, 2010 | 02:51 AM
  #1728
hyperlite21's Avatar
Thanks!
this should give you a good idea..... basically un-plug the harnesses and fish em through these holes on each side.....
Size:  53.2 KB[/QUOTE]
Old Jan 8, 2010 | 02:53 AM
  #1729
Beebo's Avatar
Thanks for the pics.
_________
Sean PM sent
Old Jan 8, 2010 | 03:27 AM
  #1730
G35Papa's Avatar
Perfect. Thank you very much hyperlite. Did you need to extend any of the wires or did they all reach?
[/QUOTE]
Old Jan 8, 2010 | 03:31 AM
  #1731
they should all reach, just un clip everything and it should make more than enough slack in order to feed em through, if you want you can also re-loom everything just to replace all the old loom as well....just more work
Old Jan 8, 2010 | 10:16 AM
  #1732
GreenGoblin's Avatar
The goblin resurrection
I extended most of mine even thru the wheel well just so there was more slack, and I could properly secure it to the inner frame rail all the way up.
Old Jan 8, 2010 | 12:18 PM
  #1733
Row2k's Avatar
20 Year Member
G35 Coupe
same here, I extended just about all of the wires in the fender harnesses. The main engine harness however had more than enought length
Old Jan 8, 2010 | 12:30 PM
  #1734
SxExCx's Avatar
I didnt have to extend a single wire for the whole tuck...hmmm
Old Jan 8, 2010 | 12:31 PM
  #1735
Row2k's Avatar
20 Year Member
G35 Coupe
Old Jan 8, 2010 | 01:28 PM
  #1736
G35Papa's Avatar
Thanks for the info guys, I appreciate it. My suspension is completely out right now and my new setup hasn't arrived yet so this should be pretty easy to get done tomorrow...finally =)
I don't want any wires around the SxExCx tanks I'll be getting
Old Jan 8, 2010 | 01:32 PM
  #1737
SxExCx's Avatar
^woot woot!
  #1738
SxExCx's Avatar
remove the hood popper/sensor too...looks cleaner
Old Jan 8, 2010 | 01:34 PM
  #1739
G35Papa's Avatar
^Good call...thanks Sean
Old Jan 8, 2010 | 09:16 PM
  #1740
Row2k's Avatar
20 Year Member
G35 Coupe
What does that thing actually do ? I mean i've driven once without fully closing the hood, it was just on with the safety latch (yea could have ended really badly but i got lucky) and no warning .... so does it do anything at all or is it in fact the single most useless sensor in these cars ?
