Engine Bay Pics*Post here*
Old Mar 4, 2009 | 01:49 AM
  #976
hyperlite21's Avatar
pray to find a used one lol thats how marcus got his on the marketplace
Old Mar 4, 2009 | 01:50 AM
  #977
g35man04's Avatar
CLUB MODERATOR
well hell they are already rare....hoping that one comes up his like finding a needle in a hay stack
Old Mar 4, 2009 | 01:51 AM
  #978
zackt69's Avatar
rarejdm.com
Yeah, with the exchange rate like it is right now it's just too ridiculous. When it levels out again, we'll start selling em again.
Old Mar 4, 2009 | 01:54 AM
  #979
g35man04's Avatar
CLUB MODERATOR
okay cool. Well keep me updated Zack..there isnt much left of ARC for me...just the exhaust and of course the expensive, oil cooler, rear dif cooler etc..but I Dont think I Will be needing those...I picked up the ARC oil pan now!
Old Mar 4, 2009 | 01:57 AM
  #980
SDGeneralCounsel's Avatar
Originally Posted by dranom
me tooooo!
Btw marcus where is the hoses connected for the catch can? any close up pics?
I don't know where the rear one is connected to. It looks weird enough that it almost looks like the install was done improperly.
On a side note, does anybody know what size hoses are used for the catch cans? I want to go with steel braded lines for my greddy one.
Old Mar 4, 2009 | 01:58 AM
  #981
zackt69's Avatar
rarejdm.com
It's installed correctly as per ARC's specs
Old Mar 4, 2009 | 02:28 AM
  #982
Dranom's Avatar
can you tell us where you guys installed the hoses zack?
Old Mar 4, 2009 | 02:43 AM
  #983
zackt69's Avatar
rarejdm.com
1 -The small hose off the catch can, on the passenger side, goes to the passenger side valve cover.
2 -The large hose off the catch can, on the passenger side, goes around the back of the engine, and to the rear of the drivers side valve cover.
3 -The large hose off the catch can, on the drivers side, goes to the intake pipe.
-Hose 2 and 3 basically replace the hose that normally goes between the intake pipe and the drivers side valve cover.
-You have to plug the vacuum line on the plenum that the small hose off the passenger side valve cover originally went to, since it's no longer used.
Confusing without pics, sorry. If you look at the pic Marcus posted, hopefully it make a little more sense. Also, keep in mind that with braided line you will have an issue getting the line to go exactly where you want it to. It's real stiff and doesn't bend as easily as rubber, so buy a little more than you think you'll need.
Now... more engine pics please
Old Mar 4, 2009 | 02:50 AM
  #984
Dranom's Avatar
Thanks zack! i think i know what your talkin about. Also where did you guys bought the hoses? its earl's right? what sizes and how much?
do you have the catch can in stock?
Old Mar 4, 2009 | 02:53 AM
  #985
zackt69's Avatar
rarejdm.com
Yeah, Earl's hoses... I can't remember the sizes, been awhile. I get all my Earl's stuff from the Earl's shop in Lawndale. Sorry, we don't have any catch cans in stock.
http://www.anplumbing.com/
Old Mar 4, 2009 | 03:18 AM
  #986
SxExCx's Avatar
^this seems like it would cause a problem. Since the vac line on the lower plenum basically acts as an oil drain; does the oil now just accumulate in the lower plenum?
Old Mar 4, 2009 | 03:39 AM
  #987
Dranom's Avatar
i remember when we open up my plenum sean its has some oil residue on it.
Old Mar 4, 2009 | 04:02 AM
  #988
k67p67's Avatar
The oil that previously made it's way throught the pcv valve and into the lower plenum should be caught by the catch can.
Old Mar 4, 2009 | 08:51 AM
  #989
g35man04's Avatar
CLUB MODERATOR
Correct what K67p67 said..thats the reason is plugs into those certain areas...
Zack when you say to the bottom of the intake pipe...are you referring to the piece that comes off the top right of the ARC intake pipe when mounted like it should instead of twisted around?
Old Mar 4, 2009 | 10:44 AM
  #990
CandlestickPark's Avatar
ill Sedan
Yes that is correct. Its on the bottom of my intake pipe (UTR), but its at the top right of the ARC intake pipe.
