S tech and H tech people lets see em!
#212
#213
I'm switching to G S-tech from Z h-tech in couple days, I hope it'll come out good.
#215
Looking at Tanabe's, all they specs have big difference front and rear, except for the Z GF210. If the drop on the G-Stech don't work for me, I'm just gonna say F-it and going Tein CS coilovers.
#216
ok, I've just switched from Z h-tech to G s-tech today. The drop is pretty even. The difference in ride quality and handling compare to the Z h-tech is minimal. I like it!
#218
Springs? What does everyone use!
Hi I'm just about to drop my 03 coupe [non sport susp] I've read all there is on springs and specs in forums etc, and I know it has been talked about many times but I want to know which spring kit will do the job or can anyone recommend the most popular spring set, I'm after a moderate drop with no camber kits or tyre wear issues if possible, the only springs as I would see doing the job are Tein Z h-tech, G h-tech or G s-tech. HELP! Thanks guys. Regards G.T.
#219
on
#220
#222
I've tried making some turns on roads I go on daily, there's a slight decrease in handling. The ride is a tiny bit more wavy compare to the Z h-techs. These springs aren't bad as most people imagine. When I drive through railroads now, it's not rough anymore. Overall, I like them.
#224
You can get away with G and Z Htechs without having a camber kit. However, I've recently bought a full camber kit for my Z htechs because surprisingly I was balding in both the front and the back. I would recommend Z htechs. Any thing in the S-techs, I would recommend a camber kit. The rears are cheap so I always recommend to buy those anyways.
#225
on
I've had no issues with rubbing. I'm running 275 tire's in the rear and never had a problem. But 350z h-techs on a g only gives a mild drop good enough for me to fill the fender gap considering i live in the northeast the roads up here arent designed to have your ride slammed so this was the best setup for me and I love the way it looks and handles.
