S tech and H tech people lets see em!
#421
rule of thumb, those who are lower than 1" drop = def rear camber kit/might need front camber kit.
#422
#423
Spacers do not affect the alignment settings. They just push out the wheels farther out towards [in some cases, past] the fenders.
#427
#428
If i didnt get an Amazing deal on these i def would have gotten the Z version for the higher spring rate.
![Name: SideProfile2.jpg
Size: 33.5 KB](https://g35driver.com/forums/attachments/picture-share/247803d1502131791-s-tech-h-tech-people-lets-see-em-sideprofile2.jpg)
#429
#431
do you have any pictures of the car. im also assuming you are on the oem wheels with the rays in your sig. but im running on the oem 18's and only have a camber kit in the rear. the front is actually doing better then i thought but with me being on the 18's thatll probably change things a little. i mean the front is a little cambered but i took it up to nissan and they adjusted on some things as much they could and they don't wear on the inside. but ya every g is different and ive seen some people down here with hella bad camber. whatever you do don't go ichiba in the front. it will be almost no help to you
#432
#434
![](http://i561.photobucket.com/albums/ss56/harrisonkrupnick/Mike%20Andrew%20Vitaly/g35Raw.jpg)
#435
