lowered the G on s techs!
Old Jun 24, 2007 | 10:43 PM
strcdan's Avatar
[IMG][/IMG]
rides soooo much better than stock!, highly recomend the G stechs,
Old Jun 24, 2007 | 10:44 PM
patman530's Avatar
looks good, are you running a camber kit with this?
Old Jun 24, 2007 | 10:49 PM
Andy2434's Avatar
Looks great! I would have to imagine that your ride is much smoother/softer now with lighter spring rates.
Old Jun 24, 2007 | 10:52 PM
strcdan's Avatar
Oh my god yea!!! Such a smoother ride softer but still firm on turns!
No camber kit needed, all wheels are in spec or close enough i wont notice excessive tire wear
Old Jun 25, 2007 | 12:30 PM
robertoluongo's Avatar
really?? no camber kit and you can have almost stock spec? NICE I am going to order a set of Stech! =P Did you had any special calibration? I was hesitating between the Stech or the Htech. I know that the Htech can have almost stock spec without camber kit but I didn't know about the Stech as well.
Thanks for the info
Old Jun 25, 2007 | 07:26 PM
strcdan's Avatar
special calibration? NO. The h techs are a barely noticable drop, the s tech os such a differance
Old Jun 25, 2007 | 07:53 PM
redlude97's Avatar
how about a alignment sheet? I just don't see how you can be back in spec with that low of a drop, and there is no way its near the middle of the alignment range
Old Jun 25, 2007 | 08:09 PM
cipriopt's Avatar
Mine are coming in on friday. Can't wait
Old Jun 25, 2007 | 08:58 PM
GreenGoblin's Avatar
The goblin resurrection
mine when I had s techs was in the middle of the alignment spec. now with my coils it is off so i needed to get a camber kit
Old Jun 25, 2007 | 09:04 PM
redlude97's Avatar
I'm not saying it impossible, I want to see alignment sheets, the vast majority of people with more conservative h-techs couldn't even get back into specs, especially on the nonadjustable fronts, so how does the s-tech magically get the alignment back into spec. My front is definetly dropped less than that, and i'm out of spec on the fronts by a significant amount
Old Jun 25, 2007 | 09:09 PM
fairwaywiz's Avatar
bump... i wanna see alignment sheets because i have always read on this forum that camber kit is needed with s techs
BayAreaRefuGz's Avatar
i fly low
i'm sitting on s-techs too. the ride is definately not smoother. it's a tad bit stiffer than stock. however, it still rides comfortably. i'm not sitting with cambers also. drove 3k without them and still looks good. my camber is off my -.60+ left and right rear springs.
Old Jun 25, 2007 | 09:15 PM
EricIsKlumzyee's Avatar
From non sport to S-Tech = Stiffer
From sport to S-Tech = Softer
There is no way you can get the toe back into specs on G35Coupe S-Techs. I had them on my old car. iono I'd like to see alignment sheet as well or go double check your alignment at another shop just to make sure you wont have too much tire wear..
looks awsome btw =)
Old Jun 25, 2007 | 11:03 PM
Queenskid24's Avatar
looks good. great job kid!
Old Jun 25, 2007 | 11:20 PM
nikkaitsme's Avatar
drop is awsome..im thinking of switching my h-tech off to 350z stechs..lol
