dropped her rear and fixed her as* crack
Originally Posted by g35cali
im thinking about cutting a quarter coil of my eibachs in the rear as well...hows the ride after u cut the coil???is it bouncier than before...looks sick
so in other words, DO IT!
u said your getting the camber kit put on soon..b4 the camber kit i was cool with how my car sat on the rear...but after installing the camber kit the gap between my rear fender and tire is larger now...i take it it was because now that the tires sit straight the car sits higher than b4...so im not sure if i should go ahead and cut the springs just yet i wanna see how yours turns out 1st after the camber kit install
i'm torn too between how my car looks and how it performs (also tire wear). you can't really tell from the pics, but my camber is pretty bad, and i decided i wanna save my tires and get more patch to the ground, even if it means sacrificing looks.
