Roberuta installed!
Old Nov 29, 2007 | 06:04 AM
  #31
imalazeeass's Avatar
theres a compresor that pumps air into the tank. The tank has a pressure sensor so it activates the compressor when it is below a certain point. The switch is a valve connecting to the lines to allow air to go in and out of the cups. When you allow air to go in, the air pushes the cups down, compressing the spring, and raising the car. The other valve releases all the air so when the air is released, the cup goes back up to the original coilover state and the car lowers back to original height. Theres also a on off switch for the compressor so you do not have to leave it on if you're not planning to use it.
Old Nov 29, 2007 | 08:37 AM
  #32
617G's Avatar
CFW (Carbon Fiber Whore)
fawking sick brah! been drooling over these for a year now lol
Old Nov 29, 2007 | 11:52 AM
  #33
G-MENTED's Avatar
that is a piece of work!
Old Nov 29, 2007 | 11:56 AM
  #34
rookie's Avatar
Nice! I wanna see it in action this weekend. Lay that Kuruma on the ground.
Old Nov 29, 2007 | 12:07 PM
  #35
TURBOTOM's Avatar
a.k.a kleicoupe
Nice, and is that an Evo 7 i see in one of those pics?
Old Nov 29, 2007 | 03:15 PM
  #36
Sportcoupe35's Avatar
Oh shoot, that's crazy!
Old Nov 29, 2007 | 03:31 PM
  #37
jdmgee35's Avatar
Wow! To see it it motion is awesome too. I remember I asked u this earlier, but did u ever find out if it messes up your alignment every time u raise/lower it?
Old Nov 29, 2007 | 03:33 PM
  #38
ltrrtl218's Avatar
they dont seem to go to low?
  #39
rookie's Avatar
Should be no different than raising and lowering you car on a lift or with a floor jack. Alignments are for the standard position, your suspension goes up and down and left and right all thought out driving. It's the straight line that you care about.
Old Nov 29, 2007 | 03:34 PM
  #40
rookie's Avatar
It goes from your set driving height up, not down. If you set your front to be low as hell it will get you up to clear driveways and ramps.
Old Nov 29, 2007 | 04:53 PM
  #41
yup, it starts from your lowest point, then goes up. As for the allignment, it should not matter because you're not supposed to drive around long term in its raised height. Keep in mind, after it is raised, it lasts about 5 min before it starts going back down to your normal height because the air cannot stay in there forever. The purpose of the kit is to raise your car when you need to clear something.. not to raise it/lower it constantly while driving around.. you need air suspension for that!
Old Nov 29, 2007 | 05:00 PM
  #42
Mike_Deezy's Avatar
Very nice, I'm so jealous.
Old Nov 29, 2007 | 05:09 PM
  #43
k67p67's Avatar
Remind us how much the hardware was. I think I recall you saying something around $2.6K.
Old Nov 29, 2007 | 05:24 PM
  #44
G35pm's Avatar
Damn, that's sick. I want some.
Old Nov 29, 2007 | 05:27 PM
  #45
accordfreak's Avatar
is the compressor fairly loud when you're inside the car?
... also what happened to the thread that had all the pictures when you first got the roberuta kit? can you post them again?
