Old Sep 28, 2010 | 04:19 PM
  #16231
erklep's Avatar
same dude i think?
and something else...
Old Sep 28, 2010 | 04:23 PM
  #16232
JBF's Avatar
JBF
Old Sep 28, 2010 | 04:41 PM
  #16233
Matzo Ball's Avatar
why does every other Subi run Rotas or Emotions? Why?!
Old Sep 28, 2010 | 04:43 PM
  #16234
erklep's Avatar
and this is just too pretty to leave out
Old Sep 28, 2010 | 04:48 PM
  #16235
JBF's Avatar
JBF
cause the only offsets available for those are perfect for subies? lol
Old Sep 28, 2010 | 04:52 PM
  #16236
Matzo Ball's Avatar
meh, that is a poor excuse
The white Lex and red Subi above are clean!
Old Sep 28, 2010 | 06:00 PM
  #16237
2g4u's Avatar
alright guys I need some help with my fitment
I added spl rear camber and toe arms which taking the spring bucket out seemed to drop the car substantially.
When I went to drive home I was rubbing on flat ground!
Is this contributed to my 275/30 on an 11 in the rear. If I switch to a 255/35 will the rub go away
It seems it's rubbing where the rear bumper meets the rear quarter.
Any suggestions?
Old Sep 28, 2010 | 06:09 PM
  #16238
TastefullyDone's Avatar
what do you mean by taking the spring bucket out? 255 on an 11 is a nice stretch, im guessing you're rubbing with suspension on full stiff and fenders rolled?
Old Sep 28, 2010 | 06:34 PM
  #16239
eurodre's Avatar
Any suggestions?
bend that bracket that is holding the two together, bend it up with a hammer and also yes a 275/30 on the 11 will be the issue as well
  #16240
Lunek's Avatar
i went from 255/35 to 245/35 and to me it is a better stretch, and for the rubbing noise the only way to get rid of it is to shave off the tab were the bumper meet the quarter panel and actually pull/flare that point out just a bit
Old Sep 28, 2010 | 06:57 PM
  #16241
Frankieg35's Avatar
Yeah for your offsets a 225/245 35 might be a better choice.. Its more of a stretch but its gonna give u more clearance..
Old Sep 28, 2010 | 07:36 PM
  #16242
xx7sephiroth7xx's Avatar
G
If you get true coilovers (where the spring goes over the shock body in the rear instead of having the spring sit in the spring bucket separately from the shock), then you can replace the spring bucket with a toe arm.
Old Sep 28, 2010 | 07:37 PM
  #16243
2g4u's Avatar
I'd prefer to do 235/255
I'll try your guys suggestions and see
Thanks
Old Sep 28, 2010 | 08:21 PM
  #16244
Frankieg35's Avatar
Yeah try it out first.. And bend those tabs..
  #16245
2g4u's Avatar
Anyone got picture of their shaved/bent up tabs?
