Old Apr 16, 2009 | 12:31 AM
  #1636
redlude97's Avatar
front camber is not adjustable
Old Apr 16, 2009 | 01:51 PM
  #1637
Royal_T's Avatar
Originally Posted by waijai
Just cuz you're on bags doesn't mean you drive 4x4 and only dumpt when parked.
True story.. I just was responding to the quote about people being slammed in pics and not really driving low. To me that is lame, but I'm pretty sure all those pics of VW's slammed, do drive their car low like that.
Old Apr 16, 2009 | 02:07 PM
  #1638
gtrefever's Avatar
i know im not saying that people with bags drives 4x4, i said bags ftw to get outta f*cked up situations i.e avoiding bumps and all that.
Old Apr 16, 2009 | 03:55 PM
  #1639
freddie07's Avatar
+1000000000000000000000000
Old Apr 16, 2009 | 04:25 PM
  #1640
w0ady's Avatar
fgc moderator
Originally Posted by Royal_T
You are correct sir.. and that is why I going this route.
good stuff. except i think all g37 rear coils have the springs mounted to the side so im screwed.
one more ? - im looking at 15mm spacers for my oem 19s, is it better to get separate longer studs or built-in? is there really a difference? thanks in advance.
Old Apr 16, 2009 | 08:29 PM
  #1641
Royal_T's Avatar
^^Good question. I don't really know the difference between the two. Do you think you will need longer studs? I need to get some longer studs to be safe.
Old Apr 16, 2009 | 08:33 PM
  #1642
Royal_T's Avatar
Kind of off topic, but not really..
DOMOI made it on Hellaflush pageDOMO....every one go check out their website and leave a comment on my pics.
I feel complete now
Old Apr 16, 2009 | 08:41 PM
  #1643
gtrefever's Avatar
yeah i seen congrats royal T now tell them to send you that sticker
Old Apr 16, 2009 | 09:25 PM
  #1644
freddie07's Avatar
Anything over 5mm while need longer studs. Lyndon, I would get the separated kind because from what I've gathered it's the safer way for your hub. I'm looking to get 10mm spacer for the rear so I've been researching for a lil bit now.
Old Apr 16, 2009 | 09:34 PM
  #1645
w0ady's Avatar
fgc moderator
true i was leaning towards 15mm with extended studs. it just means i have to find a shop to replace my studs rather than being able to put them on myself doh.
Old Apr 16, 2009 | 09:53 PM
  #1646
Royal_T's Avatar
Do you'll know any good sites that sell some studs, since you guys have been doing your research
Old Apr 16, 2009 | 10:10 PM
  #1647
freddie07's Avatar
DO you need just the studs?
Old Apr 16, 2009 | 10:11 PM
  #1648
freddie07's Avatar
and do you need extended ones or the stock?
Old Apr 16, 2009 | 10:25 PM
  #1649
GreenGoblin's Avatar
The goblin resurrection
Coz at CZP has all of them, the main difference is the longer press in studs will work with any wheel the bolt on will not. You wheel needs to have a cavity offset to the lug hole on the rear of the mounting surface, the factory wheels do lyndon, so you can use the bolt on style.
Old Apr 16, 2009 | 10:50 PM
  #1650
w0ady's Avatar
fgc moderator
thanks danny. but is either type safer?
i was going through 1 of the myg37 sponsors, cant remember who but they have both styles from ichiba in 5-20mm.
