Old Apr 18, 2009 | 06:17 AM
  #1681
Thinkdiesel's Avatar
Falken 452 stretch well, meaning they mount on easily for stretching and they look decent, but not favored for VIP platforms, mostly because of load, on 30 series. regardless, any stretch will have to be looked at regularly.
Old Apr 18, 2009 | 09:45 AM
  #1682
Invalid_User's Avatar
^what tires do you run?
Old Apr 18, 2009 | 03:46 PM
  #1683
Dem1K's Avatar
^--- T1Rs
Old Apr 18, 2009 | 04:45 PM
  #1684
robzone's Avatar
I hated my Falken 452s with a PASSSSION!!!!! bubbled up the 2nd day i had them, They could not handle my camber up front and were not worth a dime.
Old Apr 18, 2009 | 05:06 PM
  #1685
NorthSideRacing's Avatar
I had a similar problem with them also. I love how they stretch, but the bubble's and the tire wear killed me.
Old Apr 18, 2009 | 06:16 PM
  #1686
Royal_T's Avatar
Man you guys are scaring me.. So what does every on run then??
Old Apr 18, 2009 | 06:32 PM
  #1687
KSWAY's Avatar
How many miles did you get on the rears? I'm running 275/30/20 and i got like 13K out of my last set of rears. All normal driving too. Never did any crazy burnouts or drove aggressive on them.
Old Apr 18, 2009 | 06:38 PM
  #1688
Frankieg35's Avatar
I'm running 245 on 10 inch wide up front and 275 in the rear on an 11..
Old Apr 18, 2009 | 08:00 PM
  #1689
jlin615's Avatar
I'm slightly stretching Falken452 245-30/275-30 on my 9.5/10.5, no problem whatsoever. I may want to change to Toyo's 225-35/255-35 for a true stretch when I decide to add spacers.
Old Apr 18, 2009 | 09:17 PM
  #1690
Im running Toyo Proxes4. Im about to switch out to the T1r's soon.
Ever since i got picked up by Toyo. Ive only changed my tires out once a year. So the tire wear with Toyo's are badass.
Old Apr 18, 2009 | 09:28 PM
  #1691
So the I would be fine if I ran 35 front and rear?
Old Apr 18, 2009 | 10:39 PM
  #1692
T1R stretch well and they are true to size. Regardless of claims on performance, they look and wear down well for stretched setups. T1Rs dont make anything smaller than 245. So Proxes 4 is my setup front and rear 225, 245. Harder to stretch, than T1Rs, so if you're planning to mount a 245 on a 11, u have to have someone who knows how to position the tire when mounting with a bead seater (a cheetah).. Falkens 452, Sdrives, and Federals are other popular tires for stretching because they mount much easier, being slightly larger than Toyos.
Hope this helps explains teh difference.
and Robzone, we know how 452s fail.
Old Apr 18, 2009 | 11:29 PM
  #1693
Infinite1's Avatar
20 Year Member
Toyo's FTW! I have T1r's and the treadwear is awesome!
Nice pics as usual NSR! Was that at HIN? Man i missed out! I saw the vid clip of the cruise to Austin.
Old Apr 19, 2009 | 01:21 AM
  #1694
Royal_T's Avatar
So the best is Toyo, but the T1Rs don't come in 225, so next would be the Proxes... I might try them next.
Does any one know were you can get one of those bead seater (cheetah)?
Old Apr 19, 2009 | 03:07 AM
  #1695
Royal_T's Avatar
^^ never mind I found it
