Old Dec 25, 2010 | 12:24 AM
  #18646
TomieG's Avatar
Old Dec 25, 2010 | 12:34 AM
  #18647
Murfdizzle21's Avatar
still a work in progress but went out and took some pics... maybe more low and sideskirts,
Old Dec 25, 2010 | 12:36 AM
  #18648
Adon's Avatar
Pull those fenders!! What are your tire specs?? They look beefy..
fck yea bro the shop tried but thanks to my dumbassery it didnt work. Basically when I cut the fender what I did is I separated the inner fender lining from the outer fender, so when they were trying to pull the inside would cooperate but the outside wouldn't.
So basically he told me I would need a welder to re weld the seam between the inner fender and outer fender said that's the only way he would be able to do a proper roll.
specs in the rear are 12.5 with 285/30 tires and +5 offset, the front is perfect but I went too **** diesel with the rear now I see my mistake. +25 offset in the rear would have perfectly matched the front, rear looks nuts now compared to the front, looks uneven and it will look even worse when and IF i manage to actually pull the fender.
I think maybe a 10mm spacer in the front would even out the look, and it's already 10.5 with -5 offset up there too
Old Dec 25, 2010 | 12:43 AM
  #18649
CandlestickPark's Avatar
ill Sedan
^Yeah your rears are 15mm more aggressive than your fronts. Hope you get the rear fender pulled properly.
Old Dec 25, 2010 | 12:47 AM
  #18650
Frankieg35's Avatar
Damn!! Yeah I would run a spacer to even it out..
Old Dec 25, 2010 | 02:23 AM
  #18651
The Stimulation's Avatar
Originally Posted by Johnnys_Beast_Foo
^^ Imma kick you in your bad ACL bish
Bahahahhaha
Old Dec 25, 2010 | 04:40 AM
  #18652
4DGS's Avatar
I like it, definitely could get a little lower.
Kit doesn't match the wheels though IMO, the kits all like "vrooom" but the wheels are all like "chillllin"
naw I mean?
Old Dec 25, 2010 | 06:29 AM
  #18653
High Octane's Avatar
We don't need to quote all 10 pictures next time
Old Dec 25, 2010 | 10:23 AM
  #18654
eurodre's Avatar
i keel next person who quotes pictures
Old Dec 25, 2010 | 11:11 AM
  #18655
Frankieg35's Avatar
Needs sideskirts!! Do it Dre!!
Old Dec 25, 2010 | 11:26 AM
  #18656
eurodre's Avatar
Old Dec 25, 2010 | 11:40 AM
  #18657
driftsucky's Avatar
lol. such an ***.
Old Dec 25, 2010 | 05:23 PM
  #18658
ill Sedan
Old Dec 25, 2010 | 05:27 PM
  #18659
4DGS's Avatar
decent, but I'm outta VWs
Dre, come at me bro
Old Dec 25, 2010 | 05:56 PM
  #18660
eurodre's Avatar
