Yep...too low of a profile for the width plus a smaller running tire. I can go up to about -12 camber if I wanted to, but right now for the camber I'm running toe is set to the furthest I can go to be in spec. Running real close to end of threads so I have to get longer toe arms from Battle Version. I'll have much more adjustment once I get that. Hopefully Alex can tweak the suspension again and make it so the bump stops are up higher.
After I saw how thin the 30 series is with a stretch I'm kinda weary of running it. As it is my rims are about an inch maybe less from the ground and fully exposed. With the 30 series i'd lose about 1/4 - 1/2". I don't wanna risk anything. I'm just gonna have to get custom toe arms and dial in negative camber.
Here's a thought, open to suggestions. Cutting the inner fender wall so I can get more of a pull since that inner wall is holding me back from getting more of a pull. Quarter panel won't be as solid but I'm thinking of wherever it's open, having some metal welded to cover up the opening and possibly regain that structural integrity of the rear quarter. Thoughts?
