Jan 22, 2011 | 04:24 AM
  #19861
well the 285/25 is about the same size of sidewall (2.5"?) but if you're not feeling great about even doing the 30, probably not a great idea.
That's an idea... but honestly for the work that would be in it I would just cut and stitch the fender back to a more natural (but further) out position, that way the integrity would still be there and you'd have plenty of room. The only ****ty part about that is working around the edge of the rear doors. Would have to figure out a way to get around that....
Reply 0
Jan 22, 2011 | 04:42 AM
  #19862
Yeah, cutting and stitching is what I was talking about doing. The door is the main problem but the clearance issue isn't that far out towards the door
Getting into the wider tire sizes I know i'll be spending more. Trying to steer away from that. I guess I'll play it by ear. Get the tires mounted. Add negative camber for the time being. Then look into cutting the fenders. Gotta talk to my neighbor and see how much he would charge. I have an angle cutter I could use but then I'd have to pull the fenders, don't have a roller or anything. Just not sure how much I should pull it out. As far as possible without affecting where the door closes or just enough for clearance? Ultimately I would love to run less negative camber. I'd be so happy with -6. My front tires are at -5 camber and have pretty good wear on them. Or maybe I didn't get as good wear on the rears because I lowered the rear more and didn't adjust the toe.
Reply 0
Jan 22, 2011 | 05:04 AM
  #19863
^ I say just run the extra camber until you sort out the fenders.
Reply 0
Jan 22, 2011 | 05:11 AM
  #19864
Levon,
Im sure when you get your fenders opened up then youll get wider and lower offset wheels its gonna be never ending. Hahaha
Reply 0
Jan 22, 2011 | 09:35 AM
  #19865
Haha you are right.. His car would look the same just wider.. haha!!
Reply 0
Jan 22, 2011 | 11:01 AM
  #19866
holy **** those black y33s ftw
Reply 0
Jan 22, 2011 | 12:28 PM
  #19867
Lol. Na I wanna dial in positive camber cos I want more life out of the tires. If I wasn't short on cash then yeah, I'd def sell the wheels and go wider and lower.
I wish I had extra fenders, some metal, and a welding machine. Would love to mess around and make my own widebody fenders, for the front at least since those are easy to replace.
Reply 0
Jan 22, 2011 | 01:25 PM
  #19868
Reply 0
Jan 22, 2011 | 01:27 PM
  #19869
Reply 0
Jan 22, 2011 | 01:35 PM
  #19870
could use some spacers...
Reply 0
Jan 22, 2011 | 03:28 PM
  #19871
Looks good, but I personally just hate that car.
I hate the mark X
Reply 0
Jan 22, 2011 | 03:36 PM
  #19872
and it hates you
Reply 0
Jan 22, 2011 | 04:00 PM
  #19873
I'd hit it.
Reply 0
Jan 22, 2011 | 04:12 PM
  #19874
Back with the 235/35's...great fit, just wish I didn't rub.
Wheels will be back on the car tomorrow, finally! Goin in on Monday to get longer toe arms, alignment, and possibly lower the car more through Alex @ Battle Version. Can't wait.
Reply 0
Jan 22, 2011 | 04:21 PM
  #19875
Are those new wheels?
what happen to the ones that were bent?
Reply 0
