Wrong thread for that question. This thread is to show what hard work achieves, not what we answer for you.
Go to the wheels and tire section and ask in the random question thread.
please don't respond with soooo water you thinkin I do for tire?
https://g35driver.com/forums/wheels-tires-25/
right but you have to understand that stretched tires are not for looks and should only be used when needing to clear fenders and prevent rubbing
I would suggest you look around this site and others and research that before you hurt yourself or your car
we are always here to help and point you in the right direction
Problem with this is it's not how i wanna ride. I need little tire showing. Fender on rim sorta look. Doing that with 18s and this setup in the pic, car will be on the ground and not driveable. Git it?
I can only go up to page 440???
![Stick Out Tongue](https://g35driver.com/forums/images/smilies/tongue.gif)
