ill Sedan
I ordered the coils, they sent me the rear struts for 2nd gens. and said if 2nd gens were on 1st gen coils they get droppy butt look. Finally they sent me shorter rear struts, maxed out the spring. (220mm) spring, slammed it all and rear still needs about an inch more.
Gets better, a month ago, upgraded to brembo bbk, when I ordered these wheels from varrstoens, they told me 9.5 +12 clears brembos. False... after all that work with rears, cant even get the fronts on. Finally gotta 15mm spacer got the fronts on slammed it so i can clear the fenders with -3 and no pinch on the fenders. Rubbed my way home.
Finally found a 1/4 inch spacer, which clears the brembos by kunt hair. And raised the front a little to match the rear at least or else u literally slide of the seats when u brake hard.
Sent an email to Mike from bc Again. He had told me 200mm springs were on back order for 3 weeks 2 weeks ago, so hopefully he gets them in soon, so I can get my hands on them.
Next time its sunny out. Im prbbly going to remove the top locking ring of the spring, and maybe i'll cut the spring mount piece about an inch. Its just pita. Nothing goes smooth with this pos.
rant done. enjoy mexiflush for now.
When rear gets down, it clears it perfect with camber. And fronts tuck in behind the fender no problem. Just cant do it now.
