Question for you guys.
I was looking at some used Eurolines, specs are x9.5 +11 A-disk and x10.5 +7 O disk. I know that is regular disk and deep-rim disk, problem is I have factory Brembos. Looking at the pics, the front disk doesn't look like it would clear. Anyone have any experience with these wheels and BBK? I'd be comfortable running a 15mm spacer up front, but that's as far as I'd go. I'm not near the seller so I can't test fit, and he doesn't have anyone to try it.
Stock vs the exact wheel I'm looking at.
nikkaitsme (10-27-2011)
The factory wheels also have a TONNE of space from spoke to caliper. Mid disk is usually good to clear LS400 brakes and Lexus GS brakes which are about the same size as OEM brembos, so if they don't clear without a spacer, it's only going to be by a hair and you'll need a small spacer.
With a 15mm spacer you're sure. Even a lo disk with a 15mm spacer will probably clear your average size BBK.
I think I've seen the ones you're looking at. They've been up for sale for a while. Tell him to go fit them on an STI or G35 with brembos and see if they fit if you really want to confirm it. (for that matter you can test them on a 300ZX, a Supra, an LS400/LS430/LS460 Etc) He has to know someone with a skyline lol
