Old Oct 18, 2013 | 10:05 AM
  #39841
4DGS's Avatar
^ bubble butt bubble bubble bubble butt. amiright?
Old Oct 18, 2013 | 10:34 PM
  #39842
Pepper's Avatar
Still working on the rear fitment but getting closer.
Attached Thumbnails Aggressive Wheels & Stretched Tires: Post 'Em Up! [[Some NSFW]]-image-1077557907.jpg
Old Oct 19, 2013 | 02:36 AM
  #39843
4DGS's Avatar
Liked your ordens more to be honest, but I'm not huge on chrome faces for LXZs.
That front fitment is on point though man.
Old Oct 19, 2013 | 02:47 AM
  #39844
guitarrocker98's Avatar
Pepper can you PM me the specs if you dont want to post them up here?
Old Oct 19, 2013 | 04:36 AM
  #39845
Drew113's Avatar
Ban Hammer Expert
Seriously that front fitment is money...well played sir
Old Oct 19, 2013 | 09:21 AM
  #39846
Pepper's Avatar
No chrome on these wheels... Everything is polished. I liked the ordens also but I had 2 problems with them. 1. Was told it cleared BBK and it only cleared after a 20mm spacer. 2. They really hid my brakes lol. I appreciate the compliments though! Thanks!
After working in the car last night I'm pretty sure the specs are more aggressive than what I was told. I'm going to measure them once I pull the wheels off on Monday.
19x10.5 -3 (3mm to clear BBK)
19x11.5 -0
Thank you!
Old Oct 19, 2013 | 05:16 PM
  #39847
K what tires are you running. My wheels are a a half inch smaller, but they are -5 and -10. My rear tires are like 275, so I will have to run a lot of camber to make them fit. What tire your running?
Old Oct 19, 2013 | 06:36 PM
  #39848
Pepper's Avatar
I ended up with a 235/35/19 and 255/35/19. They're Toyo Proxes 4 Plus (these run large).
Here's a pic of the rear.
Old Oct 19, 2013 | 06:54 PM
  #39849
Drew113's Avatar
Ban Hammer Expert
those tires look pretty damn beefy for only being 255/35
Old Oct 19, 2013 | 06:56 PM
  #39850
Yea, I should jump on 255 I have 235 fronts I think. I just don't know. I will most likely run my 275 till they blow then re do the rear.
Old Oct 19, 2013 | 07:23 PM
  #39851
Pepper's Avatar
I tried a 275 and there was no way in hell it was going to fit since they run fairly large.
Old Oct 19, 2013 | 08:18 PM
  #39852
Yea I may just go down to a 255. Possibly get the cheapest set they have I dunno. Its close. I think with a pull they will fit. But I also have toe arms and that will change things. Your wheels are also a half inch wider per set. So that plays a little into the matter. I will have a lot of camber I think then just fix it later haha.
Old Oct 20, 2013 | 01:31 AM
  #39853
DrewDrew's Avatar
cheap...lots of camber.
surprised Blain hasn't said anything about running a 245/35 nankang ns2. a little noisy, but stretch like mad, run small, and are usually around $120 each.
Old Oct 20, 2013 | 01:39 AM
  #39854
TORETTO's Avatar
Whatever you do, do not get Federals. I have had three Federal tires bubble at the sidewall after a couple hundred miles.
Old Oct 20, 2013 | 05:13 PM
  #39855
Did you have the Federal's stretched? I never had an issue on my ride. But they WERE NOT STRETCHED AT ALL.
