Old Apr 1, 2015 | 01:27 PM
  #40831
Shanes_G's Avatar
Haha double negative offsets boys!
Old Apr 1, 2015 | 01:38 PM
  #40832
Osvaldo1064's Avatar
Car looks amazing!!!! What specs are you running?
Old Apr 2, 2015 | 02:42 PM
  #40833
KrysmethG's Avatar
Hey fellas, heres mine 20x11 et25 et15 setup on a g37x sedan. I'm fine up front but have minor issues in the rear. I'm currently maxed out in natural camber in rear at -4.5 but still rubbing slightly. Do you think if I add the camber links I can get these to clear the quarter or will I need to pull quarter some? Thanks in advance!
Old Apr 2, 2015 | 05:19 PM
  #40834
b-dRizZy's Avatar
how are you making 20x11 fit you def need a pull and some camber I have 19x10.5 with 255-35 and barely made them fit without doing any fender mod. And running -5 rear
Old Apr 2, 2015 | 05:26 PM
  #40835
drifterxG's Avatar
Yea...20x11..and it looks like you have a max-safe stretch. You'll definitely need a pull.
Old Apr 2, 2015 | 05:27 PM
  #40836
drifterxG's Avatar
I'm at 20x10.5 +15 w/-5 camber +max pull in the rear
Old Apr 2, 2015 | 05:46 PM
  #40837
KrysmethG's Avatar
Yeah I'm goin to try the camber links if not might shave down the offsets a few mm, trying to stay away from pulling quarter but if I have to I will lol
Old Apr 2, 2015 | 06:20 PM
  #40838
drifterxG's Avatar
Pulling isn't bad...just have to know someone with experience who does it good.
Old Apr 4, 2015 | 10:50 AM
  #40839
Royal_T's Avatar
Here is a little tease of my new setup.... Still need to get a alignment, my spec are all out of wack (as you can tell from the driver rear vs the passenger rear fitment).. Plan to run 0 camber/toe rear and around -4.5camber up front..
Old Apr 4, 2015 | 03:10 PM
  #40840
driftsucky's Avatar
Old Apr 22, 2015 | 11:43 PM
  #40841
_RayyyRayyy's Avatar
i know this has been asked a billion times so i know im going to get roasted but for the people on air running more that 6º of camber are the spc bolts enough to correct the toe issue?
Old May 13, 2015 | 05:48 PM
  #40842
driftsucky's Avatar
bags? lol
What toe issue are you having? Not everybody has toe issues....or bags....or only at -6degrees
Old May 13, 2015 | 09:49 PM
  #40843
Originally Posted by driftsucky
bags? lol
only -6º? sheesh and hear i am thinking im doing something major at -8º aired up
Old May 16, 2015 | 01:00 PM
  #40844
driftsucky's Avatar
You should not be -8 aired up...and if you are, it shouldn't go to -6 when aired out. It's going the wrong way. -6 aired up and -8 laid out is more logical. But, that's just camber. How far out is your toe? Also, we're both going to get flamed for discussing this in a picture thread.
Old May 21, 2015 | 10:48 AM
  #40845
eurodre's Avatar
Originally Posted by royal_t
here is a little tease of my new setup.... Still need to get a alignment, my spec are all out of wack (as you can tell from the driver rear vs the passenger rear fitment).. Plan to run 0 camber/toe rear and around -4.5camber up front..
llskiu
