Old May 13, 2010 | 11:11 PM
  #11956
TomieG's Avatar
I wanted it to be fun when i started.. It hasnt gone that way..
lol i feel your pain. Almost there though, i can see the light at the end of the tunnel.
Originally Posted by w0ady
TOMIE - why dont you try a 5mm spacer and -3 or -4 camber? im not a fan of the -5 compared to the -2 up front cause i like camber to be close to each other.
Yea im going to try a 5mm spacer next. I ran -4 w/ the spacer but i wasn't lowered that much. After i lowered it more, it still wouldn't fit even with -5 camber.
Do you guys think any universal 5mm spacer should be fine? Probably not hubcentric. I already have some rings on my volks. I hear that as long as i have about 6 threads left on the oem studs i should be good. No one makes a built in stud spacer that small.
Old May 13, 2010 | 11:13 PM
  #11957
TomieG's Avatar
Originally Posted by Johnnyone
^ don't think adding postive camber would help him. I would that for every postive camber he added it would push his wheels out another 6mm.
Well bringing in the camber would bring the top of the tire closer to the fender which in end will cause rubbing which is what im trying to prevent. You guys thinks the tire wear from -4 to -5 are that noticeable?
I mean the most everyone should expect out of their tires running ~-4 camber is about 10k miles at most.
Old May 13, 2010 | 11:14 PM
  #11958
erklep's Avatar
ive run 5mm spacers on the stock studs for a few months and been fine. i have extended studs, just havent gotten around to installing them yet. i read the same thing about the number of threads. you should be fine
Old May 13, 2010 | 11:22 PM
  #11959
TomieG's Avatar
Ok cool cool. Were yours hubcentric? Any brand you guys recommend or just any universal 5mm should work.
Old May 13, 2010 | 11:23 PM
  #11960
Johnnyone's Avatar
agree on ur statement about adding camber will bring ur tires closer to the fender. That why I said adding camber won't help.
I agree with eurodre's solution. Smaller tires wit a pull.
I had a similar issue but I resolved it with a pull and more drop which gave me more camber. Will post pic for u in a lil.
Old May 13, 2010 | 11:27 PM
  #11961
Frankieg35's Avatar
Still have to get rims fixed and adjust suspension and tweek some stuff but me and Erik (erklep) threw 2 wheels on for the hell of it..
Old May 13, 2010 | 11:29 PM
  #11962
TomieG's Avatar
Damnnnn looks nasty! lol why you working in the street?
Old May 13, 2010 | 11:32 PM
  #11963
Johnnyone's Avatar
Tomie:
I rubbed when I had ppl at the back wit this setup -2.5 camber.
then I lowered it another inch and pulled my fenders a lil more and I no longer rub with ppl in the back.
Old May 13, 2010 | 11:36 PM
  #11964
hawaiinpunch's Avatar
love your wheels bro
Old May 13, 2010 | 11:37 PM
  #11965
TomieG's Avatar
^What exactly was the process you took to "pull the fenders"?
  #11966
Frankieg35's Avatar
No step lip here..
Old May 13, 2010 | 11:39 PM
  #11967
Frankieg35's Avatar
If your talking about mine than thank u!!
Old May 13, 2010 | 11:44 PM
  #11968
Frankieg35's Avatar
There is no way I could get in his driveway..
Old May 13, 2010 | 11:45 PM
  #11969
TomieG's Avatar
Nice.
  #11970
Johnnyone's Avatar
you tube search " Eastwood fender roller" the first video is cheesy but gets the point across. would link you but posting from iPhone and I can't grab the link
