Teaser pics: Slam on DF210,Volk GT-S(+17/+18), 10mm spacer on rear!
Old Oct 7, 2008 | 10:03 AM
  #31
Cost a G's Avatar
check your toe spec on the right wheel..looks a bit off
Old Oct 7, 2008 | 06:55 PM
  #32
noize's Avatar
Cost, the right wheel does toes in while the left wheel is straight. Would a camber kit fix this?
Old Oct 7, 2008 | 07:53 PM
  #33
Cost a G's Avatar
^^ You might be able to adjust the stock toe if its still within range
Old Oct 7, 2008 | 08:23 PM
  #34
ttrank's Avatar
Grocery getter
Wow, now that's aggressive.
Old Oct 7, 2008 | 09:29 PM
  #35
Kensi's Avatar
wehre did you get the spacerss?
Old Oct 7, 2008 | 09:37 PM
  #36
Sylvan lake V35's Avatar
That sticks out more than my 12" rears . You need a rear alighnment kit ASAP the toe is out to lunch that will trash your tires in no time and obviously your camber is very uneven side to side. It will look bad a$$ when you get it all dialed in
Old Oct 17, 2008 | 09:50 PM
  #37
st350z's Avatar
Nice... so you have 15mm in the rears and 10mm up front ?
Old Oct 17, 2008 | 10:08 PM
  #38
noize's Avatar
Sorry. I have no spacer up front but just the 15mm in the rear. I had a 10mm spacers in the rear previously but it didn't clear my stock stud well enough and had to go to the next bigger spacer which is the 15mm. Might put the leftover 10mm up fron t we will see...
Old Oct 17, 2008 | 10:14 PM
  #39
G35Papa's Avatar
yeah, thats sick
Old Oct 17, 2008 | 11:11 PM
  #40
GreenGoblin's Avatar
The goblin resurrection
what are you waiting for throw those 10mm up front
Old Oct 18, 2008 | 12:23 AM
  #41
GfknDIRTY5's Avatar
G"dirty"5
Nice very clean bro.
Old Oct 18, 2008 | 01:53 AM
  #42
solopresident's Avatar
teamsolo.net im-integline
even if tires are directional you can still have them rotated in the rear if running in summer time. I would get on hands and knees every 1000 or so miles to check. or you going to go through tires SUPER FAST!
SICK TOO
Old Oct 18, 2008 | 02:10 AM
  #43
Eno19GnB's Avatar
So are you having rubbing problems? Have you rolled your fenders? Id say u should save up and at least get a rear camber kit. What brand spacers did u decide to go with?
Old Oct 18, 2008 | 07:41 AM
  #44
G-MENTED's Avatar
phat
Old Oct 18, 2008 | 11:34 AM
  #45
SIN3's Avatar
eeeek...... i just had to see it again, that rear is MONEY!
