Mod Day in SFL.DM2 Coolant Bypass and More
Old Nov 17, 2008 | 11:15 AM
  #31
w0ady's Avatar
fgc moderator
nice! looking great bruce. props to mike and ernest for helping out as always.
Old Nov 17, 2008 | 11:17 AM
  #32
Boston's Avatar
^Agreed Lyndon, they did most of the work. I was more like, "It's shake-n-bake and I helped".
Old Nov 17, 2008 | 05:13 PM
  #33
express705's Avatar
bruce you know anything about the temps?
Old Nov 17, 2008 | 07:00 PM
  #34
Boston's Avatar
Mike, you'll still need the warmer lines due to the cold weather.
Old Nov 17, 2008 | 07:01 PM
  #35
express705's Avatar
booooooooooooooooooooooooooooooooooooooooooooooooo ooooo
so i cant do it?
Old Nov 17, 2008 | 07:06 PM
  #36
Boston's Avatar
Let's ask Danny and Mike if a modified version would work. I think you'll need to get the bisquit at the oil filter.
  #37
express705's Avatar
i dont know who would know, but i also would like to know WHAT needs heating in the places where they are eliminated.
Old Nov 17, 2008 | 07:16 PM
  #38
SDGeneralCounsel's Avatar
Originally Posted by GreenGoblin
Why not been running this with greddy twins. This is also not the same as the pathfinder mod. This gets rid of the lines that go to the throttle body, the cross over and
Bruce, looks good I see a couple useless brackets and couple little things that we can do to clean it up some more....
nice. Thanks for clearing that up. I just know that the pathfinder mod is absolutely horrible and was worried that this was the same thing.
Old Nov 18, 2008 | 06:45 PM
  #39
rpm06g35's Avatar
Thanks for all the props guys on the set up for Bruce's g. Although this is a neat mod its not for the newb looking to add 5 hp. This mod wasn't intended to add hp. It was intended to add an oil cooler, eliminate the oil warmer, eliminate the throttle body warmer, add a nismo stat and last but not least clean up the engine bay. With this mod comes some serious purchasing on the owners part. New gaskets are needed back and drivers side. An oil cooler and biscuit are required, nismo stat must be purchased, and of course the pipes must be modded to get rid of all the nipples and npt plugs inserted to plug off holes. of course powder coating is optimal but spray paint works too. If anyone has any questions on this mod just ask any of us that have it. The reason I'm writing this is not to be rude but the burping of the coolant system is not for the inexperienced you basically have to almost overheat the car. This process will drive you nutz. But in the end it is worth it. I don't know how to guesstimate a prices for the total mod but we have found some deals along the way oil coolers 40$-200$, nismo stat 130$-160$, oil cooler biscuit 25$-180$ Lines and fittings 50$-150$ powder coating 60$ and the mod for the piping can be done at your local radiator shop for around 150$ All pipes and cooler should be pressure checked prior to install (HUGE MESS IF YOU CHOOSE TO SKIP THAT).ANy questions let us know Thanks again for the pleasure Bruce later Mike
Old Nov 18, 2008 | 08:22 PM
  #40
xXHotelCrazyXx's Avatar
Very clean engine bay!!!
Old Nov 18, 2008 | 08:34 PM
  #41
GreenGoblin's Avatar
The goblin resurrection
Thumbs down
Originally Posted by express705
bruce, ive been wanting to do this for quite a while.. BUT i have concerns.
its COLD up here. thats a problem. it doesnt get to 0 or anything, but the average low is 40 in the coldest month, and the record low is 2 degrees.
whats the cutoff where i cant do this mod? if i do it, will i have a problem using my car in the cold? it is my DD, and i do drive my car every day. i mean, if its silly cold, i CAN use my sisters car, but i dont think she would like that.
ALSO.
how can you clean up this mess?? seriously, is it even possible?
There is no hope.
Old Nov 18, 2008 | 08:57 PM
  #42
Boston's Avatar
Mike, thanks again for spending the whole day wrenching on my car. I learned quite a few things along the way. I think we should consider video taping the next coolant install. It would slow things down a bit but would be very informative.
Old Nov 18, 2008 | 09:00 PM
  #43
express705's Avatar
your welcome bruce
Old Nov 18, 2008 | 09:09 PM
  #44
Boston's Avatar
^How did I know you were going to respond.
Old Nov 18, 2008 | 11:10 PM
  #45
rpm06g35's Avatar
video??????? That might reveal some trade secrets. I'm not sure about that. But if it were to happen it would probably end up being a 30 min video. Not sure many people would watch the whole ordeal. I dont know maybe we will toss the idea around. later mike
